High pitched whine
Old Oct 24, 2004 | 08:59 PM
Michael Ozorowsky's Avatar
High pitched whine
Hey everyone. Just noticed this tonight. When my car is idling, it intermittently makes a high pitched whine sounds kinda like squealing disc brakes. Like this screech......Screech.....Screech. It is like every 10 seconds it is doing it. Checked all fluids, and they all look good. What could be happening? Thanks.
Old Oct 25, 2004 | 01:17 AM
AL SS590 M6's Avatar
Moderator
Re: High pitched whine
Probably the idler pulley, alternator, PS pomp. Pull the serp. belt and run it for just a short time and see if the problem is still there.
Old Oct 25, 2004 | 09:38 AM
I was thinking it was the pully as well. Don't think it is the alternator. The car will run without the pully? Didn't think it would even start without it. I'll try that. THanks.
Old Oct 25, 2004 | 08:09 PM
vetteemt's Avatar
Had the same thing happen to me this July. Found my problem when I changed my oil. Found a lot of needle bearings stuck to my drain plug. My #7 intake rocker arm blew one side of its bearings out. Replaced all the rockers with a set of Comps pro magnums and the noise went away.
2QUIK6
Sep 17, 2016 02:31 PM
HibachiZ28
Nov 6, 2015 12:53 AM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
mrwz28
Jul 8, 2015 09:11 PM
