High flow waterpumps
My stock pump is about to die, would it be worth it to upgrade to a higher flow one? From the research i've done there's not too many manufactures out there Meziere electric pumps (not too interested) Evans and Edelbrock and they are all pricey. I don't have anything too crazy going on as far as performance goes, heads and a mild cam, i don't abuse the car often so it doesn't see 5000rpm+ too much. My stock pump held up for quite some time and i didn't really have any cooling issues, i'm just wondering if it'll be sufficient enough in the long run.
Ditto. I use a Meziere only because mine is a drag car and electric pumps flow the same amount of water all the time so I get better cool down while idling back to the pits.
alex5366
Mar 8, 2015 11:32 AM
jeff94z28
Sep 11, 2002 02:01 PM
