HELP ME WITH UNDERDIVE PULLEY ASAP
i loosened the bolt and cant get the pulley itself off....
what should i do??????
Ran 13.398 with shi*ty stock bald tires havn't run with the nittos yet.
AOL SN: stik6shift98
1998 Camaro Z-28
1998 Camaro Z-28
I assume you are talking about the crank pulley? Shoot some WD-40 on it. Now you have two choices, try hitting the pulley from behind, not too hard and turn the pulley as your hitting it to make it as even as possible, or head to Autozone and borrow a pulley puller.
99 SS, Dark Metallic Blue, M6
SLP lid, KN, TBB, SLP Y-pipe, loudmouth
ported MAFs
ported MAFs
i beat the **** out of it.... and tried sprayin wd 40 i borrowed a pulley puller but it wont fit so im gonna go get anther one prob is there a trick to it..... what did u do?????
1998 Camaro Z-28
1998 Camaro Z-28
Are you using the tool to pull from the inside of the pulley?
2002 "35th Anniversary" Camaro Z28
Member Street Lethal F-Body Association of NEPA www.slfba.com
GO LIONS!!
GO LIONS!!
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Sep 21, 2015 04:31 PM
