Headers?
Old May 27, 2003 | 04:47 AM
GoFast908Z's Avatar
Member
Headers?
I've been wanting the Mac headers for a while, but I can't seem to find them by themselves (without any y-pipe).
I also noticed that long tubes are not as expensive as i thought they were. The Hooker LT's are like $420 i think. What kind of power difference is there between these two headers. I'm welding up true duals this summer, so keep that in mind. Also, how different will they sound on true duals? I don't like raspy loud exhaust, I do like very low deep rumble and roar.
Which header is easier to weld up a custom Xpipe to?
Which header is easier to install?
Oh, and for the immediate future, i will be re-using the stock cats. Until I can afford some nice Randoms.
Old May 27, 2003 | 08:58 AM
SSCamaro99_3's Avatar
With LT's the x-pipe setup would need less tubing. The sound is unreal. I have no rasp. Check out the duals thread above for a pic.
Old May 27, 2003 | 07:39 PM
GoFast908Z's Avatar
Member
ttt
Old May 28, 2003 | 03:51 AM
GoFast908Z's Avatar
Member
anybody?
Old May 28, 2003 | 09:55 AM
Mister Will's Avatar
Re: Headers?
GoFast908Z
Since you plan to run the stock cats, I assume this will be a street driven car. However, long tube headers are not smog legal in California. While long tubes produce the most gains in LS1s, they move the cats back. Since they are farther down stream from the exhaust ports, they operate at cooler temperatures which effects their ability to scrub the exhaust gases.
On the other hand, perhaps you know the right people
Old May 28, 2003 | 02:14 PM
GoFast908Z's Avatar
Member
you think the long tubes will keep me from passing emissions?
Old May 28, 2003 | 05:09 PM
stik6shift98's Avatar
i would go with lts.....emissions here are preety easy just plug in to see if u have a code or not....thats for obd2 cars only tho
Old May 28, 2003 | 09:13 PM
Technically and officially, yes.
You may pass the sniffer, but you will fail the visual.
Old May 28, 2003 | 10:08 PM
GoFast908Z's Avatar
Member
obd2?
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
