Hard question about O2 sensor simulators
Old Sep 13, 2002 | 05:15 PM
REDWS601's Avatar
Question Hard question about O2 sensor simulators
Does any one know how to make a home made version of the O2 sims?
Or does any one have and electrical schematic for an O2 sensor, or O2 sim?
Or if you know something helpful, I'd appreciate you advice,
Thanks for you help
Old Sep 14, 2002 | 01:45 AM
ScottZ's Avatar
Post
I;ve ponedered this myself. I think you would have to take the 12 volt hot for the O2 heater and step it down to less than 1 volt, run it through a timer circuit to occilate the voltage between .3-.7 milivolts and feed that signal up the signal wire. A good radio shack person might be able to tell you the components required to do that.
I am pretty certain the voltage would have to be variable, because an O2 sensor is variable. If the ECU sees no activity,just a constant voltage, you wind up with a code P1133.
Hope that is helpful
1997 Z28 MM6 Moroso CAI, Flomaster American Thunder, Taylor, Air Foil, SLP Headers, Crane Ignition, MAF, HPPIII, 4:10's, Summit Girdle, Drilled Rotors,
13.75@ 100.98 MPH
2.055 60'
New Times w 4:10's
14.3 @ 99.46 2.2 60'
Angry, but dealing with it....
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
