GM LS1 hot cam kit and 1,8 rockers......
Old Jul 28, 2002 | 02:32 AM
Sparkz28's Avatar
Post GM LS1 hot cam kit and 1,8 rockers......
I was thinking of going with a LS1 hot cam in the SS and going to an LS6 intake and a ported throttle body.....can I use 1.8 roller rockers with the hot cam kit?Or am I better off going with stock rockers?Does any company make a roller rocker with the stock ratio?Help me out guys....I need to know how I can pick up some power without a power adder or taking off the heads....
94 Z28 m6
cold air,air foil,b&m ripper,vortech tb elbow,underdrive pulley ,flowbasterd muffler,moded maf,poly trans mount,fuel pres reg,exhaust cut out........new mods 355/with 12# of procharger boost
99 Camaro SS m6
#133
MTI air lid,some free mods,B&M Ripper,MacEwen Motorsports WFG with no high beam thingy....slp longtubes w/o cats,zo6 maf,z06 clutch,jet pcm,qt cut out
Big Red(truck)
406 ci,700r4 w/3000 rpm stall,3.73 10 bolt.
No more 406..kaboom / on the way 427 mighty mouse
Old Jul 28, 2002 | 04:09 AM
Freak's Avatar
Post
you should be fine using the 1.8s with the hotcam. BUT, lets look at this a littel more closely
a Hotcam cost 450 at tbyrne maybe youll find one for 350 on a GP
the Rockers cost around 700 bucks at thunder or tbyrne
then you need the gaskets and stuff. thats about 30 bucks
And I wouldnt trust the hotcam supplied springs to work with the added lift, (the rocker kit might come with some imnot sure, but they might not work with anything but stock cam) so you might need springs 160 bucks although you can look into this
So at minimum you are looking at 1080 and it could get up to 1340
on the otehr hand, you can get a thunder racing cam, 918 comp valvesprings, pushrods, and gaskets for 700
add 100 for the titanium retainers if you want them and you are up to 800
and the thunder racing cams are far superior to the Hotcam, they are comp grinds, and almost always outperform the hotcam. I would say that the few instances they dont are due to tuning or diferent mod levels.
Old Jul 28, 2002 | 04:59 AM
Sparkz28's Avatar
Post
Well I found the hot cam kit for $391 and some change from gmpartdirect.I don't know what the best price around is on the roller rockers but that is some thing I could do later when I have the money....and the reduction in friction is what I want the rockers for.....Im just looking for a little more power with great street manners at a low cost and I think the gm hot cam is what I am after..anybody out there with the hot cam..I would like to know what you guys think about it ...or if you have heard anything about them....
94 Z28 m6
99 Camaro SS m6
#133
Big Red(truck)
Old Jul 28, 2002 | 05:33 AM
Freak's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Sparkz28:
and the reduction in friction is what I want the rockers for.....</font>
Are you aware that the stock rockers are roller fulcrum? the tips arent though. If you want stock ratio there are a couple of shaft mpunt adjustable setups out there for about hte same amount of money as the 1.8 cranes, jesel and TA I belive both have them. check out thunder racing for the TA ones, dont know where to get jesels from
The hot cam manners arent all that great IMO, that I think any of the popular TR or MTI cams (all in the 221 to 224 deg range) have better manners
Check out this page, hes got some great info gathered from lots of people on cams http://xs-fx.com/raughammer/cam_info.htm
Old Jul 28, 2002 | 08:59 PM
Sparkz28's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Freak:
[B] Are you aware that the stock rockers are roller fulcrum? the tips arent though.</font>
Yes I was aware of that....thats why I want a full roller rocker..
94 Z28 m6
99 Camaro SS m6
#133
Big Red(truck)
Old Jul 29, 2002 | 11:31 AM
JurisAg02's Avatar
Post
waste of money in my opinion....better off going to a TR224 cam or 222 duration single patter MTI cams(B1/T1). Behave alot better than a choppy Hotcam and make ALOT more power for less that a Hotcam and RR would make...with or without friction..lol
Rick
Old Jul 29, 2002 | 02:00 PM
Trevor98ramair's Avatar
Cool
DO NOT use the 1.8:1 roller rockers with the supplied springs in the hot cam kit. They're only good for the .525" lift that you see with the stock 1.7:1 rocker ratio. You'll end up with .556" lift with 1.8:1 rockers, and that will snap those springs pretty quick.
I totally agree with phatT/A that the hot cam kit is a waste of money. You're going to have a cam that is less streetable than many other cams out there, and it will put down quite a bit less power, too. The stock 1.7:1 rockers DO have a roller fulcrum from the factory, FYI. You could go with a tame 220/220 duration cam that will idle much better than the hot cam while putting down an easy 10 RWHP more. Spend the extra money now to get what you want & what will work better. If you try the 1.8:1 rockers with the hot cam kit, then I'd go with a set of Comp 918 springs.
Feel free to give me a call at L.G. if you want to talk about cams some more. We can get you virtually anything you want, and we also are making some GREAT #'s with our G5 cam. Our last f-body left with 390 RWHP with stock heads. Just call and ask for me, and I'll be glad to discuss it with you.
'02 SS: 11.63 @ 114.06 MPH, 1.588 60'; 3,515# raceweight, 1,102' D.A.
naturally-aspirated with bolt-ons, a cam, and a fat converter!
L.G. Motorsports (972) 272-7753
Check out the SS!
Old Jul 29, 2002 | 02:26 PM
Sparkz28's Avatar
Question
<font face="Verdana, Arial" size="2">Originally posted by Trevor98ramair:
</font>
I know the stock rockers have the roller fulcrum......
I want the cam (G5) that made 390rwhp with stock heads.....whats it going to cost for every thing I need?Or should I just call you at LG?
Mark
94 Z28 m6
99 Camaro SS m6
#133
Big Red(truck)
Old Jul 29, 2002 | 09:20 PM
Cool
Give me a call at the shop, and I'll get a package price for ya. I'm getting ready to swap out to this cam as well on a 111 LSA. The "standard" G5 is on a 112 LSA, FWIW.
Check out the SS!
rideordie
Nov 5, 2019 04:52 PM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
