FYI.. TSB For Oil Pump O ring.
Old Apr 16, 2007 | 12:01 PM
Bayer-Z28's Avatar
http://www.pistonslap.com/tsb/020601038.htm
01-02 Camaro
01-03 Corvette
My Lifter knock thread on LS1Tech dug up a TSB # and info.
Old Apr 16, 2007 | 06:26 PM
davidmullen73's Avatar
Is that o-ring easy to replace? I really don't know anything about these ls1s.
Old Apr 16, 2007 | 06:34 PM
DropTopZMan's Avatar
O-Ring Replacement
On an '02 Z28, would that mean removing the oil pan? What else is involved? I think I'm gonna
Old Apr 16, 2007 | 06:55 PM
Is it really worth going through that trouble to replace that o-ring? Are there any negative long term affects?
Old Apr 16, 2007 | 07:34 PM
SSpdDmon's Avatar
You don't have to remove the oil pan. But, you do have to drop the front of it to get to the oil pick-up tube bolt. That also means pulling the crank pulley, water pump, etc. It's a real PITA, but can be done over a weekend with time to spare. However, I doubt that little piece of rubber is causing all of your troubles.
Old Apr 16, 2007 | 07:55 PM
I'm not really having trouble.......have had a little valvetrain tick since I bought the car @ 54k. The dealership told me it was normal so I never bothered having it diagnosed. BTW, it hasn't gotten any worse. Would it be a good idea to have it diagnosed by a professional first?.....BEFORE I tear into the engine like that?
Old Apr 16, 2007 | 11:32 PM
Bayer-Z28's Avatar
NO! NOT easy to replace. You have to remove the: water pump, crank pulley, timing chain cover and the oil pump slips over the front of the crank shaft.
http://www.ls1howto.com/index.php?article=4
You don't have to remove the oil pan. But it would make life easier to drop it down a little to get more clearance. It seemed to be easier when the radiator was out of the way. I had more room to get my head in there to see the damn bolt. I did the oil pump on my buddy's car w/ out removing the pan, but it's a Major PITFA! I had to grind down the boxed end of a 10mm wrench to get it to fit in there. Shove some regs in the pan opening to keep the bolt from falling (if it gets loose, it won't go far.)
To get the bolt back in, needle nose and rags again. You'll see..
Also see... It really made a difference in oil pressure consistency.
If you install a ported pump, I HIGHLY recommend getting the thicker O ring. THe smaller O ring causes oil system aeration. Air in the oil means insufficient pressure to the lifters, and possibly the crankshaft. I'll have to check the oil system routing diagram again.
Ask the dealer about the TSB. Write down the # and give it to them. See if they have an LSx Tech, someone who knows a LOT about these engines. There was on here in Alamogordo, but he retired.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
NEWBIE T/A
Jun 14, 2002 12:27 AM
