Full bolt on's
Full bolt on's
What is a "full bolt on" setup with a LS1 motor. I ask this because i hear some parts are a waste of $ for the small HP gain you get. How much should "full bolt ons" cost if i do the work myself. I have a 99 SS LS1 with the stock ram air setup. Thanks, Brian Kaiser
Re: Full bolt on's
same basic idea as the lt1. a good thing to start with is the basics...intake, exhaust and handling
lid, LS6 intake, longtube headers, catback or duals, sfc, lca and sway bars if you want better handling in the curves.
Re: Full bolt on's
think you would know more w/ the extensive work you have done to your LT1....There are many bolt ons,alot useless, but the ones that really count are lid, and full exhaust(ie. headers/Y pipe/Catback)
Re: Full bolt on's
Originally Posted by Knowklew
what do you consider bolt-on?
EL waterpump
headers
catback
LS2-6-x intake
throttlebody
emissions removal
lid
filter
MAF
cold/ram air
gears
TC high stall
suspension mods
weight removal
AC/power steering removal
free mods !TB cool, EGR bobbit, smooth bellows, descreen MAF
Re: Full bolt on's
Actually, there's only two things I don't have: MAF (have one, just don't want to install it) and elec. waterpump. Other than that I'm pretty good.
As far as how much it should cost, I think if I considered my power-adder mods along with TC and gears, it ran me about $4000. I did all the work myself, except TC and gear install.
Re: Full bolt on's
Originally Posted by Loony
But some consider rocker arms a bolt on. Now what?
Re: Full bolt on's
Originally Posted by Haskin Z28
since when can you just throw rockers on an LT1? you have to to change the springs and rods too
Re: Full bolt on's
Ok I don't know if this will help:
Stock Z28 2002 Dyno #289/291
with SLP lid/K&N Dyno #298/301 cost $500
and SLP MAF
SLP ram air box
SLP Loundmouth Dyno#331/345 cost $399cat-back $1500 Headers/cats
SLP Cats y-pipe
SLP Longtubes
Ported t-body Dyno# ?? cost $100
Comp Cam & Dyno #385/371 cost$1300 including PCM tunning
Comp springs
$500 more on tunning
Strut tower brace and LCA and panhard bar I got used for $200(BMR)
Hope this helps
and SLP MAF
SLP ram air box
SLP Cats y-pipe
SLP Longtubes
Comp springs
Hope this helps
cyteone
Feb 7, 2015 06:04 PM
