Front Seal Oil Leak-Bars Leak?
Old Oct 6, 2006 | 04:09 PM
Bill'sWS6's Avatar
I have a very slow front seal oil leak. I was wondering if any stop leak products could slow it up more or stop it?
Any advice would help!
Thanks,
Bill
Old Oct 6, 2006 | 06:10 PM
94CamaroZ28's Avatar
Re: Front Seal Oil Leak-Bars Leak?
It's DEAD simple to change the timing cover AND crank seals on an LS1. Do it right, or just deal with it. I think a little external leak is a HORRIBLE reason to put something in your oil designed to plug holes... like the ones that keep your bearings and lifters lubricated.
Old Oct 8, 2006 | 07:17 PM
mook99TA's Avatar
just change the seal its easy and cheap. I never recommend putting anything into oil or coolant to seal leaks. Just leads to more problems down the road. Just my .02
Old Oct 9, 2006 | 08:56 PM
Kwiksilverz28's Avatar
I used bar stops in my old pos dd chevy spectrum. Helped me limp a leaking heater core for 2 years. Found one for $20 in the yard ($200 dealer only). Swapped it and flushed a ton of that stuff out. Worked fine.
On the other hand, never in my f-bodies, and no oil additives....
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Brake_L8
Jan 20, 2015 09:44 AM
