Front Brake Rotor Q?Q?Q?'s
Old Jan 7, 2003 | 01:04 PM
thegrasshopper24's Avatar
Question Front Brake Rotor Q?Q?Q?'s
My fiance just purchased a 2002 Camaro that has 10K miles on it. She loves the car but the front rotors are warped bad. Is there a recall on the rotors or is she stuck having to get the rotors turned after 10K miles? What I am looking for is some sort of documentation referencing the problem. I know of the issues with the rotors on the 98-02 F-bodies, just want her to have something documented to take in with her to the dealer since I will not be in town. Thanks in advance.
Old Jan 7, 2003 | 01:18 PM
6speedZ28's Avatar
No recall as far as I know...but that car should be covered under warantee. Take it in and have them changed.
Old Jan 7, 2003 | 03:16 PM
My94RedZ28A4's Avatar
Not to be a jerk, but they are not covered under warrantee. Brake pads, rotors, clutch lining, etc...
I used to write up customer complaints for Chevy so I know what I'm talking about. If the dealer does anything (even turning the rotors) I will be surprised as it comes out of his dealer "alotment" as Chevy still doesn't pay for the labor, etc...
Although some dealers will do it as a nicety with vehicles < 15k miles, so you may be in luck, but in all honesty, if the dealer does, he really is being nice.
Sorry to hear about it though, hopefully something else is wrong that caused them to warp so fast, and then the dealer would repair it under warrantee because of the other warranteed item (caliper, etc...) caused the damage.
Old Jan 7, 2003 | 03:22 PM
thehunter's Avatar
Just buy some aftermaket rotors and install new pads if the dealer won't help you.
Mike
Old Jan 7, 2003 | 03:23 PM
Z-Attitude's Avatar
My dealer told me they were covered 12 mo. and 12k miles. They just turn or replace them. I think they will back them up for 12/12 after they fix them too. I just put O'Rieley's rotors (made in USA, Wagner Rotors) on the girfriends '01 at 44k. They are regularly $49 each but they matched the price of Auto Zones (China made) rotors that were $39 each. Both looked thicker on the rotor faces than stock. Glad I could buy "American made" rotors. Later>>>>>
Old Jan 7, 2003 | 03:35 PM
Shockwave's Avatar
Lounge Moderator
How 'bout using the technical forums for technical questions?
Old Jan 7, 2003 | 11:18 PM
chuck's Avatar
AutoZone rotors hold up much better than stock and pretty cheap. You might add Raybestos Quietstops at the same time.
Old Jan 8, 2003 | 12:11 AM
GrdLockV6's Avatar
Plain and simply... stock rotors on f-bodies SUCK. When I used to have my V6, I bought it brand new. They warped at 7,000 miles. Got em turned under warranty, warped again at 9,000 miles. So I drove with em warped until like 20,000, when I said screw it and bought front/rear PowerSlot's, and HawkHPS pads. I had them from 20,000, until 47,000 when I told the car, and to the day I sold it, they were still running smooth as can be. For the price I think they're very nice rotors. For $110 per front rotor and $90 per rear, plus the price of the pads (not too much either), they're a very good investment IMO. As soon as my brakes on my T/A go out of warranty I plan on getting a set on it as well.
Old Jan 8, 2003 | 01:39 AM
W3dgy's Avatar
i had the same problem with my car. had to have them turned at just over 4000 miles. they fixed them under warrenty no problem, they said next time they will replace them... they said next time as if they know when it will happen.
Old Jan 8, 2003 | 08:32 AM
XBCHBUM's Avatar
the grasshopper..===??? Whud up wif dat, Dan?
Old Jan 8, 2003 | 10:30 AM
PAGregSS's Avatar
GM had so many complaints about the stock rotors that they actually revised the warranty to consider the rotors a non-wear item up to 12K miles. Buy some Powerstops or Powerslots and you'll be happy.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Fastbird93
Apr 9, 2016 07:01 PM
Alien
Jun 27, 2015 01:13 PM
Brake_L8
Jan 20, 2015 09:44 AM
Jul 4, 2005 05:00 PM
