Flashing check engine light/no codes set
Old Feb 24, 2011 | 08:12 PM
  #16
Marc 85Z28's Avatar
Re: Flashing check engine light/no codes set
Originally Posted by motorking
We do the same thing, we support all NHRA races with an engineer on site, something NGK does not do.
NHRA? That's small time. NGK is too busy working in Formula 1
Old Feb 25, 2011 | 05:52 AM
  #17
motorking's Avatar
Ok dude, surprised you drive an F body and not a honda with a big fart pipe. Have a great day.
Old Feb 25, 2011 | 08:15 AM
  #18
Marc 85Z28's Avatar
I'm a member of NHRA
You missed the point.
And if it makes you feel any better, I'm installing a set of Autolites into a customers Lincoln LS in a few minutes - brb.
Old Feb 25, 2011 | 08:22 AM
  #19
motorking's Avatar
Talking Re: Flashing check engine light/no codes set
I guess I do not undertsand your point. Autolite supports guys like you with real technical training and presence at drag races, snowmobile races, MX and more. I do not understand the "It's japanese so it must be better" atitude. What does playing in F1 do for you? Autolite would rather support 100 racers with 10k a piece than pay an F1 team a million dollars to run our plugs. I am very happy you are using our product, I really appreciate that.
Old Feb 25, 2011 | 10:07 AM
  #20
WhiteHawk's Avatar
I used to run Autolite 23's all day long when I had my Grand National. Never had a single problem with them. I switched to NGK TR6's on my Firehawk and never had a problem with them either. I switched mostly because I try to run what other people I know have had good experience with, not because there was an issue.
What Autolite plug do you guys recommend for a daily driven LS1?
-Geoff
Old Feb 25, 2011 | 10:48 AM
  #21
motorking's Avatar
Cool Re: Flashing check engine light/no codes set
-Geoff
Geoff,
Is it stock? If so, I would recommend the XP5245. If it is modified, need to know what has been done to recommend the right heat range. Send me your address at jay.buckley@honeywell.com and I will mail you a set to try out. And, no I cant give away 7$ spark plugs to everyone on the forum sorry..my boss would kill me.
Old Feb 25, 2011 | 12:08 PM
  #22
Marc 85Z28's Avatar
-Geoff
103 for stock, go with the APP103 if you don't mind the additional cost.
104 for most streetable boosted or H/C builds.
104 is the same heat range as the TR6, which I run in my 00TA with 11.7:1 static compression.
Make sure to close the gap down to ~.040"
Finally, I don't care to spend a lot on plugs for a precious metal tip on the ground strap that I plan to modify anyway
Old Feb 25, 2011 | 12:33 PM
  #23
motorking's Avatar
104 is one heat range hotter than 103. you are not giving correct advice, if the car is modded, you need a colder plug, running a hotter plug can drive pre-ignition and roach your motor. Please watch the heat range video on the autolite website. Autolite number is the higher the number, the hotter the plug. NGK does the opposite, the higher the number, the colder the plug. If you use our race plugs, the side wire is allready cut back and has a V trim
Old Feb 25, 2011 | 12:56 PM
  #24
chevy_dude97's Avatar
so if the original plugs are good for 100k miles, why would I go away from oem?
As in the ones engineers chose for there motor?
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
danielbmx
Aug 27, 2002 11:11 PM
