Flashing check engine light/no codes set
Re: Flashing check engine light/no codes set
I guess I do not undertsand your point. Autolite supports guys like you with real technical training and presence at drag races, snowmobile races, MX and more. I do not understand the "It's japanese so it must be better" atitude. What does playing in F1 do for you? Autolite would rather support 100 racers with 10k a piece than pay an F1 team a million dollars to run our plugs. I am very happy you are using our product, I really appreciate that.
I used to run Autolite 23's all day long when I had my Grand National. Never had a single problem with them. I switched to NGK TR6's on my Firehawk and never had a problem with them either. I switched mostly because I try to run what other people I know have had good experience with, not because there was an issue.
What Autolite plug do you guys recommend for a daily driven LS1?
-Geoff
-Geoff
-Geoff
-Geoff
Is it stock? If so, I would recommend the XP5245. If it is modified, need to know what has been done to recommend the right heat range. Send me your address at jay.buckley@honeywell.com and I will mail you a set to try out. And, no I cant give away 7$ spark plugs to everyone on the forum sorry..my boss would kill me.
-Geoff
-Geoff
104 for most streetable boosted or H/C builds.
104 is the same heat range as the TR6, which I run in my 00TA with 11.7:1 static compression.
Make sure to close the gap down to ~.040"
Finally, I don't care to spend a lot on plugs for a precious metal tip on the ground strap that I plan to modify anyway
103 for stock, go with the APP103 if you don't mind the additional cost.
Jan 5, 2015 07:14 PM
danielbmx
Aug 27, 2002 11:11 PM
