engine oil
Old Jan 18, 2006 | 05:24 AM
mook99TA's Avatar
engine oil
I normally run 10W 30 but I just bought a Mobil one fill cap and it says 5W 30 on it. WHat are you guys running?
Old Jan 18, 2006 | 05:34 AM
2000slp2768's Avatar
Re: engine oil
castrol syntec, 0w-30
Old Jan 18, 2006 | 07:08 AM
psychocabbage's Avatar
Re: engine oil
5w-30
if i could find 0w-30 mobil I would run that..
If it gets cold where you are at, i would keep the 10w for winter and 5 for summer..
Old Jan 18, 2006 | 07:12 AM
ocshaman's Avatar
Re: engine oil
keep the 5 for winter and 10 for summer.
Old Jan 18, 2006 | 10:46 AM
lastZ's Avatar
Re: engine oil
why 0-w-30 oil?...i run 5/w/30.....in the summer, dont drive it in the winter
Old Jan 18, 2006 | 11:24 AM
Greed4Speed's Avatar
Re: engine oil
5w-30 Valvoline.
Old Jan 18, 2006 | 11:35 AM
angel71rs's Avatar
Re: engine oil
An oil guru on this board and ls1tech, patman, actually runs used oil analysis tests and thinks the 30 weight M1s are too thin for best protection, show higher wear #s than his favorite, German Castrol. I like to use M1 5w-40, an oil that has gotten excellent scores on tests. But only because I can't find the GC in my area.
So why would GM recommend the thinner M1, maybe for gas mileage, don't know. All M1 synths are good oils, no doubt, but the oil tests I've read on the boards, especially BITOG, are convincing.
Old Jan 18, 2006 | 03:15 PM
Plague's Avatar
Re: engine oil
Originally Posted by psychocabbage
5w-30
Actually, 5 for the winter and 10 for the summer.
5 is thinner. So when oil is cold it will move slower. 5 will get to the engine from the pan quicker than 10 will. That is why you use 5 in the winter. If you read your manual, it says you can run 10 if the weather never gets below X degree (I cant find the exact number right now).
Old Jan 18, 2006 | 05:53 PM
Kraest's Avatar
Retired
Re: engine oil
Mobil 1 Synthetic 5w-30
transam_388
Mar 15, 2015 11:53 AM
Scottylt1
Jan 8, 2015 02:48 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Scottylt1
Dec 4, 2014 12:31 PM
Jul 4, 2005 05:00 PM
