dyno runs on the 408
Old Nov 15, 2007 | 05:58 PM
  #31
mrr23's Avatar
Originally Posted by AL SS590 M6
If your up for a little more experimentation. Throw in a set of hardened stock dia. pushrods and your stock rockers and see if the ''valve float'' goes away.
converting back to stock rockers will be a little tough to do. to fit the crane shaft mount rockers, you have to mill the heads .170" where the rocker stands are. then drill the holes and tap to 3/8-16 thread.
Old Nov 16, 2007 | 07:34 AM
  #32
AL SS590 M6's Avatar
Moderator
OK so that won't work. I was just thinking that maybe your valve train components were too heavy and causing bad vibrations/harmonics with the heavy springs. Try a different brand of spring maybe?
Old Nov 16, 2007 | 09:22 AM
  #33
mrr23's Avatar
well, i don't see what i have as being a problem. here's where vinci used the 1.7 shaft with the 833 springs and took the motor to 7000 rpms with no issues. i'm even using 3/8" pushrods. granted i'm using 1.8 rockers. so, something is amiss. for now, i'll just continue to shift at 6200 rpms. i'll work on getting the newest design AFR heads that tony and i talked about next year.
http://www.vincihiperformance.com/C6...T%20GRAPH.HTML
Old Nov 17, 2007 | 06:29 AM
  #34
Moderator
You can't compare that to yours. Different rocker ratio means that for a given engine rpm and cam lift the the valve end of the rockers and valves are moving faster. And the heavier pushrods could be the blame.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
alex5366
Feb 17, 2015 09:07 AM
Jlo
Feb 3, 2015 09:41 PM
chevysam
Jan 16, 2015 07:45 PM
birdblack
Dec 30, 2014 06:59 PM
