Don't be afraid to change your plugs!!
From what I read about changing plugs, it sounds like a nearly impossible job. I was sure I was going to get half way through and not be able to finish. I belived all of the hype mostly because I had never actually been able to see the #8 plug wire let alone the plug.
I did it this afternoon and it is a piece of cake. I took my time but I could have easily been done in just over an hour (I had a whole afternnon to kill
). The only thing that needs moved is the air tubes and that is only four bolts. The #8 plug came out of the bottom after about 10 minutes or less.
What I am saying is before you assume it is too hard and shell out $80 or more, try it. I actually had a good time (I love working on my car).
Dustin
). The only thing that needs moved is the air tubes and that is only four bolts. The #8 plug came out of the bottom after about 10 minutes or less.What I am saying is before you assume it is too hard and shell out $80 or more, try it. I actually had a good time (I love working on my car).
Dustin
actually i think i was 16 when i did it......
