Does your left front tire wear it's outside edge faster than the right ?
Old Aug 22, 2003 | 09:51 AM
NEWBIE T/A's Avatar
Question Does your left front tire wear it's outside edge faster than the right ?
It's mainly noticeable on cars where the tires do not get rotated - like if you are running drag radials in the rear.
Or, like me and just burning the Kumho's in the rear unmercifully !
At any rate, my buddies '00 SS & his wife's ex ' 00 WS6 did it.
My '99 appears to be doing it as well - not quite as much, but that may be due to the fact that I did rotate my tires one time in 22K.
Thoughts ?
Thanks !!
Britt
Old Aug 22, 2003 | 04:45 PM
SS1LE02's Avatar
Mine do. I believe it's from taking clover leafs.
Old Aug 22, 2003 | 06:24 PM
Ken S's Avatar
check your alignment.. I got my alignment checked and set on my 99 Z28 after two years of driving and I the camber was positive(which is GM spec!) but uneven.... Since I autox, I was wearing out the ouside edges alot faster, so opted for max neg camber (only got -0.5 on both sides), 4.5 caster and 0 toe.. Combine that with a 35 mm front sway bar and I have good wear, and alot better cornering grip up front..
Old Aug 23, 2003 | 05:23 AM
GoFast908Z's Avatar
Member
you might also want to check that the wheels are balanced properly, and that you didn't throw a wheel weight.
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
70rs00z-28
Sep 6, 2002 08:13 AM
