Does the stall only work on the 1/4 mile?
Old Oct 28, 2004 | 09:39 PM
  #16
1stls1's Avatar
Re: Does the stall only work on the 1/4 mile?
Ok, ok, I'll get grip and a conv next!
Old Oct 28, 2004 | 11:46 PM
  #17
Onez4u2bn's Avatar
Ok guys. I got 3.73's in my car. When tax season rolls around im gonna have the QTP headers and a 4000 Yank Converter because im gonna get the Heads and cam package and thats what Yank recommends. If I put it in before I get the H&C what can I expect out of my car with 3.73's LT's and that 4000 stall? Will it be streetable? Im pretty sure it will scoot on down the road but im mainly worried about how streetable it will be.
Old Oct 29, 2004 | 03:39 AM
  #18
AL SS590 M6's Avatar
Moderator
It'll be streetable but your tires will hate you.
Old Oct 29, 2004 | 09:13 AM
  #19
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Smile Re: Does the stall only work on the 1/4 mile?
Originally Posted by 1stls1
Oops, I guess that will be my next venture. I'm waiting on lowering springs, rumbler cat back,3.73 gears,lid(carbon fiber), and the preditor diablo.
I too have 3.73 gears, and a word of caution, I would NOT go over a 3200 stall 2.2 STR, unless you want some serious traction problems.
I have a Y3000 2.0 STR coupled to my 3.73's, and with full rear suspension upgrade using BMR components, WITH sub frame connectors, it still gets a little wild.
JMHO
SteveC
Old Oct 29, 2004 | 12:32 PM
  #20
Onez4u2bn's Avatar
what do you mean wild? You mean, when starting from a stop light or sign if you accidently give it to much gas it will squeal tires or it will do it all the time? Or just no traction when you punch it?
Old Oct 29, 2004 | 02:31 PM
  #21
SteveC's Avatar
Thumbs up Re: Does the stall only work on the 1/4 mile?
From a dead stop, @ 3/4 throttle, the rearend will want to come around on me, and this is with 35MM front, 25MM rear, solid sway bars.
I drove in a friends vehicle that had the stock 3.23's with a Vig 2800 2.5 STR, and he was going sidways from a dead stop. This looks impressive, however you are going no where, and wasting E.T.
I would get the gears, and match the converter to them.
Good luck.
SteveC
Old Oct 29, 2004 | 03:12 PM
  #22
BirchMan98z's Avatar
Originally Posted by darrens99formul
At 15 mph maybe.But at 30 mph with stock HP/TQ the only thing going sideways in a M6 is your butt if it itches and your trying to scratch it on your drivers seat
Have you ever driven a 6 speed ls1? They will get sideways at just about any speed in 1st gear-- which is good for 46-47mph. 30 mph will certainly get sideways, especially with our higher 3.42 gears.
Old Oct 29, 2004 | 03:52 PM
  #23
darrens99formul's Avatar
I have driven a bone stock 99 Z28 M6. At 30mph it would not go sideways by just nailing the gas because there is enough traction at that speed to prevent such a violent outcome. I'm not saying you can't chirp the tires, I'm saying with bone stock power, stock gears and stock tires your not going "sideways" by punching the gas at 30mph.
Ok maybe in real cold weather you could but I'm talking a 75-80 degree day, sun shining and a dry street.
Old Oct 29, 2004 | 09:43 PM
  #24
zo6vette's Avatar
JMHO
SteveC
so then how do you launch your car with your mods and set up without spinning alot? whats the best way that you launch your car off the line?
Old Oct 29, 2004 | 11:16 PM
  #25
nikkev's Avatar
If you just lightly press on the gas your car will drive like normal. It's only when you lay into the gas pedal that the stall comes alive. If you were to get in my car you couldn't even tell I had a different stall unil you punched it. I have a Yank 3200 stall with a 2.5 (or 2.0 can't remember) STR.
Old Dec 5, 2004 | 10:45 PM
  #26
zachw1036's Avatar
This is my next mod. I cant believe I almost spent the money on a hood. Good thing I found this thread again.
Old Dec 6, 2004 | 03:39 AM
  #27
jasons93z's Avatar
my m6 will go way sideways in 1st and kick back in 2nd and in 3rd. I have quite a few mods though.
Old Dec 6, 2004 | 06:38 PM
  #28
med_reject's Avatar
A stall will help you as long as its bringing you into peak torque band. WHen it pushes you beyond that, i.e. higher rpms, then for that bit of time its hurting you. For most of the rev range, its helping, so overall, it will improve performance at just about any speed.
Old Dec 6, 2004 | 08:47 PM
  #29
V6toZ28's Avatar
JMHO
SteveC
Or he can just learn how to handle it ....
<-------- 3.73s w/3800 stall, 2.85 STR hooked to 403 rwhp H/C
Old Dec 7, 2004 | 12:07 AM
  #30
luv2spd's Avatar
Mine does that too! Bone stock it would chirp from a 20 punch. With the lid it would start to lose traction at the top of 1st, with the headers/ory it would demolish the tires in first at any speed, now with the big cam.....well lets just say i don't get any traction till third right now. I've got new tires on the way though along with some new rims!
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
