dang.. didn't expect this at 13k... problems...
Old Mar 18, 2005 | 10:36 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
my babes bangin off the rev limiter... redlined it on an onramp today... banged hard 3 times and fell back to about 5 grand before upshifting.... did that a few times as i tried to see if it would keep doing it... not ALL the time... maybe 40%
then on highway... smashed it to redline 2nd... held steady at 4 grand 82mph... no acceleration like i hit some kind of governor...
and this may just be me being paranoid.... but i THINK the trannys actin funny... maybe slipping? i could be makin that up tho
thoughts?
Jared
Old Mar 18, 2005 | 11:22 PM
CrabhartZ28's Avatar
Re: dang.. didn't expect this at 13k... problems...
eesh. that doesn't sound right. My first thought was a computer problem, but that seems entirely too squirrely for the common corruption. I would definitely get that tranny checked if i were you. You can always replace the chip, the tranny'll be another 3-5 grand.
Old Mar 18, 2005 | 11:31 PM
ULTIMTEORANGESS's Avatar
whats the condition of your fluid and the level?
Old Mar 19, 2005 | 12:34 AM
frmula1's Avatar
checking the fluid first thing tomorrow... but i checked it when i bought it about 5 weeks worth of driving it ago.... it was nominal... and i def haven't done anything to it to cause it to come from fine to failure in these 5 weeks
Old Mar 19, 2005 | 09:48 AM
Reznor's Avatar
13k, still on warranty?
Old Mar 19, 2005 | 09:50 AM
LapeerZ28's Avatar
I had the same symptoms. Fluid was low. The connection to the cooler was leaking. It blew the 3-4 shift clutch in the auto. Luckily they covered under warranty as the shop had to rebuild the transmission. So rebuilt tranny at 75K miles.
Can't complain, but in the auto if you start hitting the rev limiter on acceleration, check the fluid and look for/fix the leak.
Good luck,
Tony
Old Mar 19, 2005 | 01:13 PM
frmula1's Avatar
i've been under it a bunch of times... no transmission fluid leaks that ic ould see
checked the fluid... was a little low... drove about 10 miles or so round trip to autozone and bought two quarts was b&m trick shift... got home, checked the level again with the tranny up to temp.... it was reading in the 80 degree area where im pretty sure it should have been in "hot" 80/warm/hot are the stages it was about 3/4in low on the dipstick poured in one quart took it for a 5 minute spin... came back checked it again... now its reading about 3/4in OVERFULL
tried to redline it a bunch of times... but without going 90mph on the street i could only do this for the 1st/2nd shift, which is hard to do with the *** end being so squirrely... i did notice a quick sputter once tho at about 5200 still... never really got to redline it properly under full traction
i THINK i might still have like 2months on warranty... i have to check
thoughts?
Old Mar 19, 2005 | 04:34 PM
frmula1's Avatar
s'getting worse... and the tranny fluid is actually a little overfull... and its got a real sluggish very powerless period too high of a rev 1-2 shift at very partial throttle... definatly think the transmission is screwed.... but why the hell isn't the fluid burnt? alot of black stuff came off the dipstick when i rubbed it with a white paper towel... but the fluid itself that drips off it seem fairly clean, clear and red
Old Mar 19, 2005 | 04:44 PM
maybe its valvebody related or something electrical.
Old Mar 19, 2005 | 08:38 PM
9TransAM4's Avatar
i know exactly what you are talking about. i have a '99 T/A and i have been having the exact to the T problem that you are having. i still have a warrenty till 75K and i have 47K on the clock now. i have taken the car to a GM dealership, and Carmax(where i bought the car) and both have told be that there is nothing really wrong because as you said my tranny fluid was perfect and that diddnt warrent them going into the tranny. i have been furious about this, because i know my f-bodys and i know there is a huge problem. my car too feels sluggish like it doesnt want to shift into gear right away from the 1-2 shift. for example, when i make a turn at 15mph, my rpm's will rise higher than normal, and finally shift sluggishly. also at highway speeds, i will punch it and like you said you are having, my car bounces off the rev limiter a bunch of times and finally shifts..... but it doesnt feel like it has the pull up top like it should. so if you find out anything about your problem please let me know......
Nick
Old Mar 19, 2005 | 10:32 PM
frmula1's Avatar
wow... 75k warranty.... lucky
yep i checked.. mines up in april... im gonna take it in monday... but your post has me worried. what do you guys think about dropping the pan and filling the tranny with burnt fluid? to ensure i get what i need?
Old Mar 20, 2005 | 01:41 PM
9TransAM4's Avatar
yeah i suppose you could do that...... however if they end up telling you that there is no problem, just take a mechanic out for a ride with you and tell him exactly what you are noticing. i have gotten to the point where i need to do that as well
93 RedBird
Nov 15, 2015 08:24 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
damnyankee36
Sep 9, 2015 07:06 PM
WPHIG2
Aug 27, 2015 06:37 AM
