Damn bumpy ride is annoying me, help please
Old Nov 13, 2003 | 12:25 PM
96Z28man's Avatar
OK, I have rod bearing LCA's and Panhard rod on my car. THe back end sounds like a damn 18 wheeler when i hit even the smallest bump. I'm thinking the tightness back there probably fried my shocks, right? Anyway, what r the best, sturdiest replacements I should get?
How hard is it to install rear shocks?
Tks in advance
Old Nov 13, 2003 | 03:21 PM
CODY BEHNKE's Avatar
With no bushings the ride will be rougher and more noise will be translated into the chassis.
If you do change the shocks it's pretty easy, the top of the shock can be accessed by fliping down the rear seat and lifting up the carpet (you may need to remove the trim panels) they are under the foam blocks.
Old Nov 13, 2003 | 07:05 PM
Greed4Speed's Avatar
Re: Damn bumpy ride is annoying me, help please
The "sturdier" the shocks the harder the ride also.
Old Nov 13, 2003 | 07:16 PM
99BlackZ28T56's Avatar
If you have the $$ get adjustable shocks. Rear noises will still be there with new shocks if due to the LCA's and pahard. Shocks are very easy to install. Only takes a few minutes with air tools.
Old Nov 14, 2003 | 02:17 AM
96Z28man's Avatar
so should i get rid of the rod bearing stuff and get ones with bushings?
Old Nov 14, 2003 | 04:05 PM
Ken S's Avatar
that or make sure you have high quality rod ends and make sure they are clean and tight. else they are guaranteed to make lots of noise.. some people say they can get em quiet if they use good ones and take care of em.. some say its still impossible.. but all cheap ones makes noise regardless..
Old Nov 14, 2003 | 05:48 PM
96Z28TealM6's Avatar
I just recently put a set of HD Bilstein with stock springs..and it's stiff the way I like it but the back still has some bounce to it though...maybe I need to replace the control arrms?
cristian1311
Sep 12, 2015 08:16 PM
WPHIG2
Aug 27, 2015 06:37 AM
NewsBot
Aug 21, 2015 07:20 PM
Boss002
Jul 24, 2015 10:47 AM
cmsmith
Jul 5, 2015 07:23 PM
