cut out
Old May 12, 2003 | 06:03 PM
ERIK93Z's Avatar
Wink cut out
i have a 02 ws6 i installed an electric cut out
tapped into tcs per macord instuctions,but
keep on blowing fusses.i ran a wire dirrect to
battery still blowing.ground wire is mounted
to chassis.what could be the malfunction.
Old May 12, 2003 | 06:33 PM
stik6shift98's Avatar
tap it into something else
Old May 12, 2003 | 06:41 PM
2001NBMZ28's Avatar
If you're blowing fuses there's a short somewhere. I have the QTEC and wired it to the radio fuse (no TCS) for power and the black wire on the cig lighter for ground. I helped a friend install the McCord the same way without any problems. If it's wired correctly the short may be in the switch/led/motor or your ground is incorrect.
Old May 12, 2003 | 07:22 PM
doesnt neccessarily have to be a short it could be an overload
Old May 12, 2003 | 07:44 PM
ERIK93Z's Avatar
cut out
thanx for the suggestion nbmz28 i'll have to try
it tomorrow.if it was a bad ground my test light
would not light up when testing the ground
right?when i ran the wire to the battery it blew
a15amp fuse as soon as i tried the switch.
Old May 12, 2003 | 08:48 PM
2001NBMZ28's Avatar
I assumed you were using an OHM meter to test for ground. I have a "screwdriver" type tester for power, one end goes to ground, the other end "lights" when connected to power. If you go power to power you'll blow a fuse. Might want to check the ground again. If it's a good ground give McCord a call. Hang in there, the electric cut out is a great mod - I love mine.
Old May 12, 2003 | 09:15 PM
99BlackZ28T56's Avatar
Make sure you didn't pinch any wires. Did you try the cutout before you installed it?
Old May 13, 2003 | 09:51 AM
94B&RZ-28's Avatar
I ran the switch into my ash tray, tapped the cig lighter for power and grounded it to the frame. I have the MCCP2 and am very pleased with it.
Old May 13, 2003 | 12:01 PM
bbentley40's Avatar
If you are testing a ground wire and something is lighting up that is bad. Unless like 2001NBMZ28 said you are using a Ohm meter or something, but even then it should read 0. Ground it to the ground on the cig lighter, that is how I did mine and it worked fine.
Old May 13, 2003 | 12:33 PM
rncotton's Avatar
I tapped my McCord into the TCS switch and had no problems.
Shoot me an e-mail -- WS6@BlackWS6.com and I'll tell you which wires I tapped into (and send a digital pic)
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Oct 4, 2015 09:47 PM
