cut out
i have a 02 ws6 i installed an electric cut out
tapped into tcs per macord instuctions,but
keep on blowing fusses.i ran a wire dirrect to
battery still blowing.ground wire is mounted
to chassis.what could be the malfunction.
If you're blowing fuses there's a short somewhere. I have the QTEC and wired it to the radio fuse (no TCS) for power and the black wire on the cig lighter for ground. I helped a friend install the McCord the same way without any problems. If it's wired correctly the short may be in the switch/led/motor or your ground is incorrect.
cut out
thanx for the suggestion nbmz28 i'll have to try
it tomorrow.if it was a bad ground my test light
would not light up when testing the ground
right?when i ran the wire to the battery it blew
a15amp fuse as soon as i tried the switch.
I assumed you were using an OHM meter to test for ground. I have a "screwdriver" type tester for power, one end goes to ground, the other end "lights" when connected to power. If you go power to power you'll blow a fuse. Might want to check the ground again. If it's a good ground give McCord a call. Hang in there, the electric cut out is a great mod - I love mine.
If you are testing a ground wire and something is lighting up that is bad. Unless like 2001NBMZ28 said you are using a Ohm meter or something, but even then it should read 0. Ground it to the ground on the cig lighter, that is how I did mine and it worked fine.
I tapped my McCord into the TCS switch and had no problems.
Shoot me an e-mail -- WS6@BlackWS6.com and I'll tell you which wires I tapped into (and send a digital pic)
