coolant leak, please help diagnose
Old May 28, 2003 | 09:16 AM
ZZed's Avatar
It appears to be coming from the lower right bolt on the front cover plate. (while looking aft) That's the best I can trace it. The bolt is not loose and the only work I've had done in the area is the alternator bracket SB. It flows down then drips off the oil pan. The leak stops once the engine reaches operating temp. I'm at a loss. Could it be the overflow, the water pump??? Please help.
Old May 28, 2003 | 10:01 AM
My84Z's Avatar
maybe i am thinking of the wrong place but check the coolant hoses on the bottom of the throttle body.
Old May 28, 2003 | 11:25 AM
ZZed's Avatar
It is at the bottom of the engine near the oil pan, right side, front of engine. Coolant is actually running down the block. Car is stock.
Old May 28, 2003 | 03:20 PM
KungFu's Avatar
Headgasket? Waterpump?
Old May 28, 2003 | 07:17 PM
Kwiksilverz28's Avatar
That is where the thermostat is. Check the hose there. Mine never leaked, but the GM factory clamps are worthless in my experience....
Old May 28, 2003 | 10:42 PM
chris mac's Avatar
i've got the same thing. mine (the best that i can trace it) is coming from the water pump. i could be wrong, though.
mac
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
jwade88
Jun 14, 2015 09:38 PM
Blood type Z28
Apr 8, 2015 11:34 PM
dansam
Jul 20, 2002 01:10 PM
