Coolant Bypass Q
Old Feb 14, 2007 | 06:23 PM
Bayer-Z28's Avatar
Coolant Bypass Q
My buddy and I installed a new set of stage 1 LS6 heads and the MS4 cam.
THere are coolant bypass ports on the back of the heads. How do we block these off? It also seems that either head can be mounted on either side. -Am I crazy on that last one?
Old Feb 14, 2007 | 06:28 PM
AL SS590 M6's Avatar
Moderator
They are the same as the heads you took off. Unless your also putting a LS6 intake on, just use your old parts.
And both heads are the same and interchangeable.
Old Feb 14, 2007 | 07:13 PM
Bayer-Z28's Avatar
oh. I forgot to mention , it's on his 02 SS...
Old Feb 15, 2007 | 03:55 AM
DaddySS's Avatar
Still, I assume you are talking about the steam relief ports on the top/back? The parts from the old heads should be replaced there no?
Old Feb 15, 2007 | 05:49 AM
Bayer-Z28's Avatar
^ yeah. The bypass for the front is in it's usual spot, no prob there... I was just wondering what to do w/ the back. I'll check the old heads after work... I didn't even think to check there..
one last stupid question... It seems like you can almost mount either head on either side... is this true? I don't think we paid too much attention.. We just threw the heads on. They bolted up fine. We got em tq'd down last night. should be running by sunday..
Old Feb 15, 2007 | 06:49 AM
Capn Pete's Avatar
Al already answered that question for you ... YES, they're identical!!! (which has pretty much been the case forever with most heads)
Old Feb 15, 2007 | 08:38 AM
Moderator
Yep when posting a question it's always very helpful to read the responses.
Old Feb 15, 2007 | 08:49 AM
Capn Pete's Avatar
Old Feb 15, 2007 | 12:32 PM
Bayer-Z28's Avatar
oh... duh... ....
I knew that was there but for got to look again... I suppose it wasn't the BLUNT answer I thought it was... I'm a little slow at times...
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
