convertible leaking???
Old Jul 10, 2003 | 07:10 PM
reddog930ss's Avatar
Sorry if this is the wrong forum I didn't see anything for basic Tech questions. I just bought a 99 SS convertible and have a small leak from the drivers side window. Before it was leaking from both sides but after I wiped all the seals down with armorall it stopped on the passenger side. What else can I do or check to correct the problem.
BTW all the seals appear to be in excellent condition!
Joshua
Old Jul 10, 2003 | 09:07 PM
mvs's Avatar
mvs
1. Check the window alignment. Make sure it seats against the seal.
2. Make sure that the latches truly clamp down the top.
Manny
Old Dec 11, 2004 | 07:25 PM
01Ragtop's Avatar
Re: convertible leaking???
Had the same driver leak problem on my 01 Convertible until today. Check out the point where the windshield weatherstrip mates with the convertible top weatherstrip. There's a hole about 1/4" in diameter that drains this joint down through the weatherstrip to the bottom of the door hinge area. I carefully poked a coathanger through the hole and it stopped about 4 inches from the bottom of the weatherstrip, just where two rubber sections are fused together. I poked through this rubber "membrane" to allow the internal gutter to drain water from the joint, and the problem went away. Some sort of factory flaw, in my case. Perhaps a mud dauber or leaf debris obstruction in other cases.
PCLZ28
Dec 24, 2015 05:19 PM
WildRidez
Feb 23, 2015 07:24 PM
ChrisFrez
Feb 15, 2015 07:49 AM
94_Z28_ragtop
Aug 19, 2002 06:49 PM
