Code P0420
Old Jun 24, 2004 | 05:28 PM
RxNupe's Avatar
Code P0420
The Autozone description says "Catalyst system efficiency for bank 1 is below threshold for the current engine operating conditions."
Is this a problem with oxygen sensors? I only have 37,000 miles.
Old Jun 25, 2004 | 08:35 AM
RxNupe's Avatar
HELLO????!!!!!
Old Jun 25, 2004 | 08:37 AM
shortdog273's Avatar
It's one of your 02 sensors behind the cat.
Old Jun 25, 2004 | 08:40 AM
RxNupe's Avatar
I guess so...everything is in stock order
Old Jun 25, 2004 | 09:18 AM
2001NBMZ28's Avatar
It's either the rear driver's side 02 or the cat itself. The cat is covered under warranty for 8yrs/80K.
Old Jun 25, 2004 | 07:26 PM
mrr23's Avatar
when i got that code, i took it ot the dealer. they replaced the driver's cat. no more code. you have an 8/80k warranty on it. they'll replace it. mine went at 49k.
Old Jun 26, 2004 | 11:45 AM
RxNupe's Avatar
When I had my LT1 I could pull the PCM ign & batt fuses in order to reset the PCM to erase the code. I tried it with my LS1 and it didn't work. Are there any other tricks to resetting the PCM?
Old Jun 26, 2004 | 12:46 PM
2001NBMZ28's Avatar
To reset:
Turn key on - don't start car.
Pull PCM BATT & PCM IGN fuses.
Wait 5-10 min.
Turn ignition off.
Replace fuses.
It'll work if the problem has been corrected.
Old Jun 27, 2004 | 04:28 PM
rncotton's Avatar
By any chance are you running Hypertech power tuning?
lt1matt
Mar 21, 2015 07:35 PM
johnsocal
Aug 29, 2002 10:01 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
