Clicking Sound
Old Apr 1, 2010 | 04:16 PM
  #16
cwhite32's Avatar
Originally Posted by cdmelcher
Clicking Sound
I've heard this same thing, only possible additon would be my earlier post about SES Code 0442 (EVAP - lean fuel) which I had cleared at Autozone. Anyone get this code along with this problem?
And lets say it is anyone of these things, whic is the worst to have - I would think the lifters????
Yes, Actually I had that error code pop up about two months ago and cleared it. But now I am getting the light tapping/clicking noise but mine I have only noticed getting onto the freeway then it sticks around untill i pull off and stop to check it out then mins later its gone, even when I leave it running.
Old Apr 1, 2010 | 08:32 PM
  #17
johnny6's Avatar
Well i sure hope the OP fixed his problem since only 4 years have passed.
Old Apr 2, 2010 | 07:06 AM
  #18
Kraest's Avatar
Retired
Old Apr 5, 2010 | 01:53 AM
  #19
cwhite32's Avatar
Any Ideas as to what it could be?! I know that exhaust leaks make a sort of similar noise and so does a jammed valve or bad lifter... But only seems to show up on the freeway..but not even when I run it harder in town.. so im not sure. Any help is much appreciated! Thanks!
-Chris
Old Apr 5, 2010 | 10:56 AM
  #20
johnny6's Avatar
-Chris
What grade fuel are you using?
Old Apr 5, 2010 | 08:45 PM
  #21
cwhite32's Avatar
Always Premium.. I AM almost due for an oil change anywho and today I put some Additive in. So I will see if it clears up some. I am 99% sure its a lifter.. If I end up replacing the lifters any ideas on ways to soup her up while im in there?
Old Apr 6, 2010 | 12:08 AM
  #22
rod442's Avatar
Maybe you have a bad rocker or bent pushrod. But that probably wouldn't go away like you explained. Either way, check them all carefully before you get into lifters.
Since the heads have to come off to replace the lifters, that would be a prime time to do headers and heads/cam/intake. the cam adds some work, but the rest will be loose/removed. if the budget isn't there, a cam based on stock heads will still perk it up a lot.
If you dont do a cam, check the lifters really carefully. I had a tick I thought was a lifter at 33k miles. pulled em all, didn't really see much issue with them and put it back together with new ones. Noise still there. It ran ok, so I drove it another 15k miles and put in a built shortblock and finally found the issue.
What had happened is that I had a badly heat treated cam and a lobe edge wiped right off. you could barely see a knurled edge on the lifter roller (I had them around, so I went back and looked at em again). It almost needed a magnifying glass to see it. and with oil coating them, we missed it. the new lifter on that lobe was obviously beat to hell, when it got tore down the second time.
So basically, I took it apart too soon the first time. lol.
May 21, 2015 01:04 PM
REDNECKISBOSS
May 20, 2015 10:03 PM
May 15, 2015 10:43 AM
cmsmith
Apr 30, 2015 05:18 AM
HuJass
Jun 27, 2002 11:04 PM
