Check Your FAST 92 Bolts?
Old Apr 14, 2009 | 12:29 PM
  #16
BadgeZ28's Avatar
Sounds like a non issue to me. If you torque them correctly on install and re torque after a couple heat cycles, then you are done. Stop obsessing.
Old Apr 21, 2009 | 08:51 AM
  #17
89385formula's Avatar
Mine loosen up too. I have had to retorque 2x since having the car back out. I defn wouldn't stop thinking about it, because if they loosen up it will leak at some point. I have already seen that happen. If it does it again, ill go right to red loctite....but that really shouldnt be necessary.
Old Apr 22, 2009 | 07:55 PM
  #18
Sunsetmaro's Avatar
Did you change out the valley cover bolts? I think on the 92mm fasts, its suppose to come with bolts for the valley cover, more low profile ones...Actually im sure of it, Ive seen them installed. Those bolts are shiney ones too..
maybe2fast
Mar 16, 2015 09:45 AM
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
