Check Engine/Service Engine - MAF error
Old Jan 12, 2006 | 09:56 AM
  #16
shmuck2003's Avatar
Re: Check Engine/Service Engine - MAF error
Thanks guys!! I will pick up a "fuse assortment" today, and try the 30A first. thanks for the guideance on where to find the air pump in case I need to examine/replace it. I'll try it out today and let you guys know how it went. It's likely you all have saved me a lot of shop-rate money... where do I send the check?
Old Jan 12, 2006 | 11:21 AM
  #17
shmuck2003's Avatar
Hi guys, I got fuses, and unfortunately, its instanly blowing the 30A. When I pull the AIR relay, it doesnt blow. I disconnected the air pump (see picture, tell me if I found the right component here!!) it still blows. So, if I have done this right, I either have a bad relay (unlikely) or a short in the wiring harness (seems more likely..). if you can take a look at this picture and let me know if I did disconnect the air pump like I think I did...
DirtyDaveW
Dec 1, 2016 05:37 PM
pete53
Dec 9, 2014 07:31 AM
danielbmx
Aug 27, 2002 11:11 PM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
