Cheapest emissions legal LT header setup
Old Apr 27, 2004 | 11:21 AM
RxNupe's Avatar
Most of the emissions legal (with cats) LT header setups I see (FLP, SLP, QTP) cost $1200 and up. I'm looking for the cheapest setup because I'm going to have pay for installation as well. I would like to attempt the install but I don't have the time nor resources to do it. Any suggestions?
Old Apr 27, 2004 | 12:33 PM
darrens99formul's Avatar
Cheapest route by far is getting yourself a set of Pacesetter or Flowtech LT headers. Then buy a pair of inexpensive HF cats like Carsound. I think you also need a pair of 02 simms. Don't bother with the ORY. Bring all the above to whatever exhaust shop/performance shop is doing the install for you.
They can fab you a 3" y-pipe for probably $100 which is cheaper then a traditional ORY. Have them weld the HF cats into the fabed Y pipe.
Pacesetter coated Headers $410
Fabbed Y-pipe $100
02 Simms $90 (if needed)
Pair of Carsound Cats $200
So parts total is roughly $800 and then install would be on top of that number. I'm guessing your looking at $400 for install but you'll have to check around and see what deals you can find because I am not sure. Bare in mind that replacing non-defective cats or relocating cats from the factory posistions is in violation of the Federal Clean Air Act. So not every shop will be willing to do this work so don't be shocked if a few places you call refuse to give a quote. I would check the Non-franchise exhaust shops and or performance shops like speed inc.
Good Luck
Old Apr 27, 2004 | 05:17 PM
teke184's Avatar
flowtech coated headers $380
not sure of the cats and ypipe...
but combine that with at least a $20 online order discount through thunder racing....and they are cheap
and check out page 11 of my website (sig) for a detailed install guide
Old Apr 27, 2004 | 05:28 PM
Knowklew's Avatar
Any set of longtubes is illegal because it moves the cats from their stock location. so if you want to pass visual then your screwed. but if you just want to pass the sniffer then just make sure you run some cats.
Old Apr 27, 2004 | 06:02 PM
RxNupe's Avatar
The sniffer is all I'm concerned about.
Old Apr 27, 2004 | 07:45 PM
Pewter Z's Avatar
Check to see if your local laws require exhaust testing. Mine only require (on 96 and newer cars) the OBD II to report 'A--OK' and they give you the sticker.
If they can take that as an emmissions test then your all set! Put the LTs on, throw away the O2 sensors and cats then go find a cool person with LS1 Edit and your problems are solved.
(If the mechanic looks under your car during inspection then just say 'Yeah, I got lucky, my cats blend in soooo well with my exhaust and look so perty )
Old Apr 28, 2004 | 12:43 AM
Flat_Tire_'s Avatar
They're inside the pipes
And if they ask you what that smell is ... use this line "Sorry, I had a killer lunch at the Grand Enchilada"
Old Apr 29, 2004 | 04:56 AM
AL SS590 M6's Avatar
Moderator
Keep in mind that there is no such thing as an emissions legal long tube header set up. Having cats doesn't make them legal. All long tubes and mid length move the cats and that will fail your visual inspection if they look.
Old Apr 29, 2004 | 09:08 AM
RxNupe's Avatar
Generally where I'm from, they just stick the sniffer in your tail pipe for a few seconds and get a carbon monoxide and hydrocarbon reading. The only visible inspection they do is check your lights, turn signals, park brake, etc...
Old Apr 29, 2004 | 03:46 PM
Ryuhei's Avatar
RxNupe-
If you're in Illinois you don't have to worry about the sniffer. In 1996 and newer cars they just hook you up to a computer and as long as you're not throwing codes, you pass. They only put you on the treadmill and sniff if it's OBDI (1995 and older). they made it EASIER to pass with no cats as long as you know what you're doing.
Old Apr 29, 2004 | 04:38 PM
Omega9's Avatar
I'm glad we don't have to go through that emmisions bullsh|t in Kentucky.
Old May 3, 2004 | 12:40 AM
RxNupe's Avatar
Yeah it's all a PITA.
Old May 3, 2004 | 01:34 PM
MikeyG's Avatar
Yeah, gotta love FL, no emissions BS here either.
Old May 3, 2004 | 01:53 PM
Capn Pete's Avatar
Here in Ontario we have emissions testing, but it's a sniffer test, and it doesn't matter where the cats are, as long as they're installed.
Funny thing is, I got to see first hand how cats don't do squat to help your emissions.............when I had my '81 Z28 a couple years back, I had to take it for an e-test. Well, it failed, so we installed a pair of cats 'cause I didn't have any in at the time. After they were in, I ran the car down the street in 1st gear to get the exhaust nice and hot, then we ran the car again. It failed worse than without the cats?! So we had to [cough] "adjust the fuel" [/cough] to make it pass But it did, and that was running a pair of LT's and cats on a ~375 HP carbureted 383.
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
Firemechanic
Parts Wanted
Dec 14, 2014 10:22 AM
