changed spark plugs, now hesitates
Old Nov 26, 2006 | 08:08 PM
  #16
Marc 85Z28's Avatar
Originally Posted by A&FLs1
I believe the plugs with a .060" gap is intended for a FI or No2 set up. Some buy them because they believe the plug is better since its intended for higher horse set up but dont know that there is a difference in the gap or why. Therefore .060" pregapped is not incorrect. Just not intended for all cars.
You've got it backwards. Nitrous and boosted cars have much higher cylinder pressures which often "blow out the spark" on plugs. To combat this, you CLOSE the gap, often to around .035"
Old Nov 26, 2006 | 08:57 PM
  #17
A&FLs1's Avatar
Actually now that you say that...that does sound right. I stand corrected. So why does NGK pre gap a spark plug that is specific to our engine with the wrong gap for different plugs?
Old Nov 27, 2006 | 06:04 AM
  #18
Marc 85Z28's Avatar
That spark plug is not specific to the LS1. It is used in other engines. And although the manufacturer may recommend a .060" gap, the LS1 runs better on a smaller gap. It's been proven time and time again.
Old Nov 28, 2006 | 08:10 AM
  #19
AL SS590 M6's Avatar
Moderator
See that's the thing. The factory recommended gap is .060 so the spark plug manufacturers when building a replacement plug spec out a .060 gap.
Many years ago some industrious hotrodders tried NGK copper plugs in their LS1s and found out that they work just a little better than stock for high performance applications. During their research they found that tr55 were the right heat range and depth but with a .050 gap and it worked well so now most that run their cars hard or at the track use the copper plugs and the smaller gap for more consistant spark under extreme conditions. Tr6s are one step colder and many use them for FI and NO2.
For a daily driver that isn't going to get beat on much I'd stick with a quality Platinum or Iridium and tighten the gap to .050-.055. Why put in a copper plug that will need to be changed every 10-30k (depending upon tune and usage) when you can use a plug that will go 50k or more?
Old Nov 30, 2006 | 11:15 AM
  #20
btz28m6's Avatar
what is the ect sensor?? will it make a car miss or run rough if it is unplugged or broken?
thanks bobby
Old Nov 30, 2006 | 05:11 PM
  #21
Zitty'sZ's Avatar
ect = engine coolant temperature.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
Dark Zeiro
Mar 11, 2015 07:15 AM
jasonduaine
Mar 7, 2015 09:44 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
