Catback Question
Old Sep 4, 2003 | 10:43 AM
02Camaroguy1775's Avatar
Catback Question
I know this might be kind of a stupid question, but I don't know a lot about exhaust work. How hard is it to install a catback by yourself? I know there are some kits that are supposed to bolt on, but is there any welding involved at all? Will the integrity of the system be weak if it isn't welded? The guy at my local shop can install a Flowmaster catback for just over 300 bucks, but I figure I might be able to do it myself cheaper.... any input would be appreciated.
Old Sep 4, 2003 | 10:49 AM
SunsetWS6's Avatar
Installing a catback isn't that hard. Whatever you do don't get a flowmaster exhaust. They are one of, if not the worst flowing aftermarket exhausts period.
Old Sep 4, 2003 | 11:01 AM
teke184's Avatar
most kits can be installed using just clamps. which is an adequate means to connect the pipes. just be carefull not to clamp down too much, some clamps will crush the pipe, causing a smaller diameter.
most slip fit connections with a simple band clamp will make for a good solid leak free seal.
$300 just to install a cat back? or does that include the cost of the system?
i had my magnaflow welded up (bought it used so it was cut off) for $100 at a local muffler shop.
Old Sep 4, 2003 | 11:36 AM
Yeah, the $300 was for the system,extra parts, and installation. So Flowmaster is the worst kind to buy? I'm not just looking at flow, I also want it to sound good
Old Sep 4, 2003 | 06:01 PM
zoomjrl's Avatar
flowmaster sounds good, but doesn't flow as well. I love the flowmaster sound, alot of people that have flowmasters just get cutouts.
Old Sep 4, 2003 | 10:06 PM
Capn Pete's Avatar
Cool
I just put the Flowmaster cat-back on my car about 2 weeks ago, and without a dyno to prove one way or the other, I don't think there's any power lost. The car will still break the tires loose from a roll like nothing, and regardless of how the Flowmaster compares to other aftermarket systems, it still flows better than the factory system, and it sounds 100 X better than the factory exhaust!
$300 for the whole system and installation? Sounds like a good deal to me!
Old Sep 5, 2003 | 09:34 AM
SiggyZ's Avatar
Not hard at all. The hardest part for mine was removing the factory exhaust. Installing the Loud Mouth was easy. Took about 3 hours to do the whole project.
Old Sep 5, 2003 | 12:17 PM
95GRNZ's Avatar
Thumbs up
Very well said!
TS
Old Sep 5, 2003 | 09:31 PM
CamaroBoy96Z28's Avatar
Installing a cat-back isnt too hard. I did it myself with 2 friends on a lift. It was a Borla system and didnt exactly have the greatest fit. My Hooker seems to fit perfectly. I had to have it installed because my custom y-pipe didnt come close to fitting the Hooker I-pipe. $125 to modify the y-pipe and put the cat-back on and weld it together.
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
thenewkid
Nov 27, 2014 09:41 AM
