catback install question
Old Jul 28, 2006 | 06:03 PM
CAMAROZ28AQUINO's Avatar
just installed magnaflow catback, in the instructions it said to disconnect battery so the computer can reset itself. i forgot to do this and left it on. does this matter at all? thanks
Old Jul 28, 2006 | 06:05 PM
95Z28DROPTOP's Avatar
Re: catback install question
It doesn't matter at all.
Old Jul 28, 2006 | 10:04 PM
Cruz3's Avatar
On occasion, you may need to "reset" the computer. You disconnect the battery for 15 minutes or so, then let it idle for 5 minutes with no accessories running. My parent's had a maxima that was running rough and this trick cleared it up. I'm going to do the reset trick on my car since I just got the catback/flowpac installed just in case. Supposedly the car will "learn" how to run after a few miles, so this trick just makes it happen faster.
Old Jul 29, 2006 | 12:02 AM
AL SS590 M6's Avatar
Moderator
It's easier to do it right.
turn the key on but don't start the motor
In the under hood fuse panel pull the PCM bat & PCM ign fuses
Wait about 5 minutes
turn key off and re-insert fuses
done
Old Jul 29, 2006 | 12:09 AM
Moderator
Originally Posted by Taintedz28
^^^^ cool trick
8 year old cool trick. Been at this a while.
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
thenewkid
Nov 27, 2014 09:41 AM
GigaMp3z
Feb 20, 2003 02:57 PM
Chrisdude
Jul 24, 2002 02:25 PM
