cat-back
Old Jun 11, 2003 | 08:50 AM
zman28000's Avatar
Question cat-back
Would it make sense to buy the cheapest cat-back, then change the muffler out till you find the sound you want? Like a hooker catback with a borla muffler? Aside from the muffler, What are the differences with the 3" tubing?
Old Jun 11, 2003 | 10:17 AM
SSCamaro99_3's Avatar
If you are going to be changing mufflers that often, I would stay with the stock pipes. Why cut up an expensive catback? There is no real advantage to the 3 in pipe as you have 2.75 in pipe, until you start making some serious hp.
Old Jun 11, 2003 | 05:14 PM
silversupersport's Avatar
just save for a borla and then run it fully open. or you could be cheap like me and get a cutout.
Old Jun 11, 2003 | 05:15 PM
ratio411's Avatar
Thumbs up
What he said!
The power increase from a cat-back is all in the muffler.
The .25" larger pipe does nothing for a mild car, and when you get to the point where it would help, a 3.5" or 4" system would be better. 3" systems are a waste IMO.
Dave
Old Jun 20, 2003 | 11:54 AM
zman28000's Avatar
So I know you can buy a magnaflow or flowmaster muffler individually, but what about corsa or borla? anyone know if these are available anywhere?
Old Jun 20, 2003 | 01:38 PM
SSpdDmon's Avatar
Did you think about a custom dynomouth (dynomax) setup??? If you can find a decent, reliable exhaust shop that you can trust, they should be able to fabricate a custom system from the cats back (including a y-pipe) that would be awesome. Usually, the custom dynomouth design has a bullet muffler at the end of the drive shaft and the rest is just straight piping. Saw it on my friends LT1 T/A and it looks & sounds awesome. Just my .02
http://www.cardomain.com/member_page...=215971&page=2
Old Jun 20, 2003 | 10:15 PM
Greed4Speed's Avatar
Alunamized doesn't rust out that quickly. My wife's car has ~113000 miles w/aluminized piping that is still solid. My 70 SS had aluminized pipes that looked like new even after 3 years. And yes, it was driven in snow and rain. You can put at least 2 aluminized systems on for the price of stainless.
Old Jun 21, 2003 | 02:08 AM
dmnall's Avatar
Originally posted by ratio411
What he said!
Dave
Dave, you are completely right on the pipe subject!! I have posted in the past that 3" does nothing for a stock car, but other people have tried to argue that simple fact and say that 3" pipe will sound better and out flow... Well for one, I cannot see how .25" larger diameter is really going to outflow the stock pipe, it will but not much to say more HP involved... Personally, when I start doing more mods like H/C swap, LT, ORY, then I will upgrade my stock I-pipe to 3.5" - 4" depending on what heads and cam I go with... or maybe a true dual 3" setup!!! I agree that 3" is useless because the Stock I-Pipe flows well enough for a stock car and the Pipeing is not holding a car back, but the muffler is the restriction in the Stock Exhaust.. Replace it with either a Bullet or Magnaflow and you will be a lot happier and w/ more money in your pocket..
Again, I recommend the Dynomouth mod to everyone who asks about my car...
Charlie
Old Jun 21, 2003 | 04:11 PM
JaysZ's Avatar
What he said!
Dave
Agreed. I'm running the stock I-pipe with a Magnaflow and I'm flowing real well. I doubt a 3" I-pipe would've given me anything more.
marlar98
Oct 21, 2015 02:02 PM
R@mpage
Apr 20, 2015 10:02 AM
jasonduaine
Apr 1, 2015 08:09 PM
Mister Will
Sep 19, 2002 09:06 AM
Desolate_Flux
Sep 6, 2002 05:14 PM
