Car wont Start!
Old Dec 5, 2004 | 12:57 AM
  #16
Mister Will's Avatar
Re: Car wont Start!
Originally Posted by LcukyStarZ28
If I mis understood I'm sorry but isn't he reading the voltage off the battery not the battery leads to the starter so there will be no resistance so his voltage reading will be correct. So his voltage can still read 12.66+ and his Cold cranking amps still be too low to turn the car over.
Oh, I should have made it clear I had the battery out and tested at Kragen. The battery is clearly in great condition.
I do agree with you. You can put a meter across a dead battery and get 12 volts (I've experienced that personally). However, it won't be able to crank your engine over.
Old Dec 5, 2004 | 01:10 AM
  #17
Re: Car wont Start!
Originally Posted by RedThunder1994
usually a starter wont just go out all of the sudden you'll notice it a little at a time
Now I know it was the starter. I didn't notice anything until it wouldn't turnover. My engine turns over very easily. It didn't take much to push start it. Even after 6 years, all I have to do is twist the key, without pushing the gas, and it starts right up. Since the engine starts so easily, perhaps it covered over any signs that the starter was going bad.
The starter went out with no warning. It's just like a few years ago with my battery. I noticed a slight hesitation in the morning. I figured the drive to work would charge the battery sufficiently. But that afternoon, nothing. The battery was nothing but dead weight. Once I replaced the battery, the engine started up right away and the car stopped running like it was possessed which is another story.
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
