Can a Tach be corrected
Old May 17, 2007 | 07:44 PM
badazzcamaro97's Avatar
I just bought a 2000 SS with a M6.The tach says it idles at 1300 rpm, so I hooked up a scanner and found out that it actually idles at 800 rpm. We varied the throttle and the tach is always about 500 rpm too high.So my question is can this be fixed and what should I look for to fix it.
Old May 17, 2007 | 07:58 PM
it sits on the peg
Old May 17, 2007 | 08:14 PM
RE AND CHERYL's Avatar
If it's always off by 500 RPM I would pull the plastic cover off the cluster, remove the needle, and installit at the right RPM using your scanner.
P.S. I had to do this to my wifes 96 vert.
Re'
Old May 17, 2007 | 08:18 PM
Thats a good idea.I should I have thought of that before.
Aaront810
Aug 29, 2020 09:34 PM
drt
Sep 27, 2015 04:39 PM
Fatdog2
Sep 16, 2015 11:04 PM
tommalcolm
Sep 11, 2015 03:39 PM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
