Camaro SS 1998 code too lean
HI do you think the probleme are the fuel pump , the fuel regulator, .Man i lost around 10 mph on a 1/4 miles, I change the knock sensor, the mass air flow, my plugs look goods too, i think i gonna change my fuel pump and i see after the result! i have a k&n complete kit (air filter,and the cai) the car run normal but less power, the check engine light are not open but the code flash around 2 time per summer , I need help
Could very well be a fuel filter problem. Get the codes scanned and see what's in the history.
10 mph is a TON unless you're comparing it to winter times at 0 DA compared to 2000+ DA in the summer. The summer heat/humidity can cost you upwards of 5 mph.
hotrodyou1
Dec 20, 2014 10:05 PM
Dec 5, 2014 11:42 AM
Dec 1, 2014 08:08 AM
Jul 4, 2005 05:00 PM
