camaro LS1 stock fuel pressure ??
Old Jan 17, 2011 | 09:00 PM
ram air camaro's Avatar
i tried the search but nobody has a simple question on their and im tryin to know all the facts of my car but having trouble looking for this one,,,
my 2000 z28 a-4 shows 49psi on ignition on
and 59psi while the car is on
is this normal ????
Old Jan 18, 2011 | 02:44 AM
rod442's Avatar
Re: camaro LS1 stock fuel pressure ??
Sounds about right. stock running pressure is 60. mine will prime the system to the stock setting when the key is first turned to the "run" position, and then drop a bit untill the car is started. Once running, its back up. If that makes sense.
or in other words, it doesn't hold the pump on, primed, pressure when the car isn't running. it cycles the pump to raise the pressure in the rail for a few seconds just as you turn the key on. If the car doesn't run, it kills voltage to the pump. All normal.
Old Jan 18, 2011 | 06:37 AM
AL SS590 M6's Avatar
Moderator
is this normal ????
yep
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
