cam tool, how does this thing work?
Old Sep 27, 2006 | 12:38 AM
mvvette97's Avatar
I see on the cam tool it has a flat side along the rod. What is that for? Also how does this work? does the rod set below the rollers on the lifters? I was going to try and make some but I didn't know about the flat spot.
Old Sep 27, 2006 | 05:41 PM
mook99TA's Avatar
Re: cam tool, how does this thing work?
If its the rod that is about as long as your heads it is to hold your lifters up while you change your cam. You will use this tool so that you don't have to remove your heads to change the cam. You can also us magnetic retrivers and slide them into the pushrod holes and pull the lifters up but that is a ballzy move if you ask me. Go with the rods they work very well.
Old Oct 1, 2006 | 09:23 AM
rickys93z's Avatar
were can i get these??
Old Oct 1, 2006 | 09:42 AM
AL SS590 M6's Avatar
Moderator
Check out our supporting vendor list. I think that Thunder Racing sells them.
Old Oct 1, 2006 | 09:57 AM
rickys93z's Avatar
thanks
Old Oct 1, 2006 | 10:12 AM
mvvette97's Avatar
i think I'm going to just make some out of 5/16 rods
Old Oct 1, 2006 | 09:17 PM
jay_lt4's Avatar
i made mine from wood dowels, it worked very slick, spin the cam a few times and push the dowels in and pull the cam out for less than $3, i think they want like $100 for the actuall tool
Old Oct 1, 2006 | 09:21 PM
mvvette97's Avatar
what size are they?
Old Oct 1, 2006 | 09:28 PM
jay_lt4's Avatar
5/16" x 20 1/4" long, i sanded the 1 end till it had a beveled edge on it so it would slide in easier, and the 1 on the drivers side was a snug fit so i sanded the dowel a little till it fit in nice and smooth
rideordie
Nov 5, 2019 04:52 PM
parkers Z28
Mar 11, 2016 08:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
Hal Fisher
Sep 14, 2002 09:36 PM
