Cam too big for daily driver?
Old Jun 22, 2005 | 05:54 PM
slayer6x6's Avatar
Im thinkin about buyin a 99 SS with 225/225 .595/.595 144lsa cam. I drove the car, and when coming out of first slowly, the engine almost wants to stall. It also has a real lumpy idle. Off idle the thing is a monster, but do you think that this is too much for a daily driven car?
Old Jun 22, 2005 | 06:06 PM
myslowcamaro's Avatar
Re: Cam too big for daily driver?
should be no problem. i could use mine as a daily, but dont to keep it in emissions exemption. i still have stock tc, and 3.23 gears so gas isnt affected that much.
Old Jun 22, 2005 | 06:10 PM
teke184's Avatar
i drive a 233 cam every day...
because the cam increases power in the upper rpm, sometimes they are touchy in the lower area, hence the trouble pulling out.
you have to get use to it, and you'll adjust how you slip the clutch so you don't stall it
the TR 224 cam (similar to yours) is one of the most common daily driver cams around.
Old Jun 23, 2005 | 11:11 AM
Greed4Speed's Avatar
You'll just go through springs quicker also.
Old Jun 23, 2005 | 02:17 PM
slowpoke96z28's Avatar
nothing 4.10s can't take care of
Old Jun 23, 2005 | 02:26 PM
Brangeta's Avatar
I wouldn't buy a car for a daily driver that was difficult to drive... I'd only get more and more annoyed as I drove it...
Old Jun 26, 2005 | 09:01 PM
slayer6x6's Avatar
What kind of life expectancy should I count on for the springs? Will they just get weak and start floating valves, or could the possibly break and drop a valve in the cyl?
alex5366
Feb 17, 2015 08:12 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
cmdeshon
Dec 12, 2014 10:51 PM
Snoman73
Nov 17, 2014 07:22 PM
