cam selection
Old Mar 12, 2005 | 07:27 PM
heavy_chevy29's Avatar
cam selection
my friends girlfreind smacked up her 2002 z28. i work at a bodyshop and we have to replace the entire front end of the car(from the firewall forward). need less to say we are pulling the motor. he was talking to me about swapping a bigger cam in. being how the motor is out now would be the easiest time to do so. he was wondering if there are any cams that are worth putting in with out having to change the springs. im a camaro nut but i really don't know that much about the ls1. let me know you guys think. thanks alot.
dan
Old Mar 13, 2005 | 08:42 AM
Nsty98LS1's Avatar
Re: cam selection
any cam besides the stock one will require springs. the GMPP Hotcam, and ASA cam will require at least a LS-6 spring but some people upgrade to the comp 918's, but then you never have to change springs again. don't forget the car will need a tune after a cam also. i would do all the bolt ons first and then worry about the cam. also is the car an m-6 or a-4. if a-4 get a torque converter first at least a 3500 stall.
Old Mar 13, 2005 | 08:49 AM
Re: cam selection
thats what i thought. the car is a m-6
Old Mar 13, 2005 | 09:31 AM
teke184's Avatar
Re: cam selection
Comp Cams LS1 Camshaft - 206 / 212 .515 / .522 112 LSA 800-5800 RPM Power Band.
that's one of th only ones i've seen that doesn't NEED new springs. stock are good to .525" or so.
it would be close...but you could run it.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Dec 17, 2014 11:00 AM
Black Sunshine/ 00SS
Jul 29, 2002 11:57 PM
