cam newbie question
Old Sep 8, 2003 | 02:00 PM
jpz28's Avatar
cam newbie question
Thinking of getting the TR224 cam. What kind of maintenence is involved? Do you have to replace you valve springs every so many miles, etc.?
Old Sep 9, 2003 | 01:42 AM
Got-LT1's Avatar
Cams these days reall don't have to be maitained like older ones did. Back in the days of the muscle cars (circa 1960s- 1970s) the perfonace cams needed to have their valve springs adjusted (most used a solid lifter cam, at least that I know of) and for some reason (forget what) they needed constant maintince. Today's cams usually don't need you to do that. I am not familer with the cam you are talking about (I do have an LT1 )but odds are it will not need constant mantiance. Hope that helps.
Old Sep 9, 2003 | 02:04 AM
AL SS590 M6's Avatar
Moderator
Re: cam newbie question
Only if you get into a really high lift with single springs.
With a TR224 there shouldn't be any extra maintenance.
Old Sep 9, 2003 | 07:51 AM
jpz28's Avatar
Thanks for the replies. I will probably go with either a .563 or .581 lift with rev springs.
Old Sep 9, 2003 | 11:23 AM
V6toZ28's Avatar
Most folks with over 560 lift on single springs recommend a spring change once a year ... depending on how hard you run the car, eventually you will break a spring ...
oldschool
Feb 9, 2016 09:21 PM
Z28countrymama
Jan 22, 2015 02:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
