Cam installation question
Old Mar 26, 2005 | 04:57 PM
slick willy's Avatar
Iam having a new cam installed along with longtubes headers,The shop
owner says he has to pull the engine to get clearence for cam installation.
Is this correct?
2002 Z28 all stock except for lid
Old Mar 26, 2005 | 05:30 PM
myslowcamaro's Avatar
Re: Cam installation question
yes unless you take the front of the car apart. may be another secret to it but easy to drop the motor.
Old Mar 26, 2005 | 07:51 PM
Detroit454's Avatar
I was told that if you have a lift you can drop the radiator and install it that way
Old Mar 26, 2005 | 08:01 PM
D James's Avatar
no no no you don't have to. Just have to take off the waterpump and pully and timing cover off, you don't even need to remove the intake manifold. The radiator must come out and the AC radiator must either come out or be pulled up out of the way. I took mine out so I wouldn't break the lines, then I just filled with more AC stuff. Most guys just bend it up out of the way, but once all that is clear its very easy to put in. Make sure he uses a new bolt for the harmonic balancer pully. Check out this http://www.installuniversity.com/ins...sity/index.htm
Old Mar 26, 2005 | 08:31 PM
DaddySS's Avatar
If it's not too late I'd take it someplace else that does work on LS1s. Only the radiator needs to come out. Move the AC condensor out of the way and it will slide out.
If it is too late - give him a copy from LS1 how to.....
6speedZ28's Avatar
Yep, this is how I did mine!
Old Mar 26, 2005 | 09:17 PM
thanks for the info guys,no,its not to late.He is also taking heads off to
port them,I dont think that makes any difference though.
Old Mar 27, 2005 | 05:36 PM
Kyle@CSS's Avatar
You do not need to pull the engine at all. You have to remove the radiator and condensor of coarse. If you were close I would work on it. I only charge $400.00 to swap them out.
Old Mar 27, 2005 | 09:22 PM
Detroit454's Avatar
Damn thats an awesome price! I wish I was local to SC
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
