Bubbling sound from coolant?
Old Nov 11, 2004 | 06:17 PM
ggsz28's Avatar
This may sound stupid but I've never noticed this sound before. Got out of the car today and could hear the coolant sound like it was slowly boiling (like a slow bubbling). Anyways, the temp gauge was normal before shutting it off. I didn't notice anything until I stopped the engine at which time I popped the hood to listen and it sounded like it was coming from the passenger side of the block. I've never heard the coolant make noise like that and it really grabbed my attention. Do I just need to bleed some air out?
Old Nov 12, 2004 | 05:41 PM
FastrDamnit!'s Avatar
Re: Bubbling sound from coolant?
Sounds like your radiator cap is causing the bubbling your hearing. Not holding enough pressure.
Start there, should fix it.
Good luck
Old Nov 12, 2004 | 05:48 PM
mudpuppy's Avatar
Might sound like a heater core.
Old Nov 13, 2004 | 01:20 AM
ggsz28's Avatar
So I could hear a slight hiss (very slight) from the cap so does this mean it was letting in air and so the system needs to be bled or do I just need a new radiator cap? The bubbling sound was definitely coming from the block/head area and not the radiator.
Old Nov 15, 2004 | 01:53 PM
Just bleed the system when you get a new cap. LS1s are much easier to get the air out then the reverse flow LT1s, even with their built-in bleeder valves.
If you need help just IM me, I live in SD too.
Ivan
blac94Z
Feb 15, 2021 09:43 PM
Sandersen511
Jan 13, 2015 03:49 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
