borla exhaust installing question
Old Jan 27, 2003 | 06:00 PM
fiz's Avatar
fiz
I used to have the Borla adjustable catback on my '02 v6 bird.. but i changed it awhile ago. I installed the borla myself, but then had it taken off, and had a different system welded on
I'm planning to cut off the current system and put back on the borla but I'm confused about how to install it now. When I first installed it, no welding was involved.. where does the first piece of the I-pipe go... directly into the cat? or into the s-pipe piece that goes into the cat? I'm confused because it looks as if it will need to be welded even though it's a bolt on system
does anyone have any good instructions with pics, or the real instructions? the ones I found online were ****ty and vague.
thanks for the help
Old Jan 27, 2003 | 09:16 PM
OctaneZ28's Avatar
Disciple
Having not ever installed an exhaust on a V6, I can only go on an educated guess, but I would imagine that since on a V8 car the I-pipe attaches to the Y-pipe, then the I-pipe on a V6 attaches to the S-pipe.
Sorry I can't offer more information, but I hope this helps.
Old Jan 27, 2003 | 10:03 PM
stik6shift98's Avatar
im confused i have borla on mine ill do my best to help as much as i can
Old Jan 27, 2003 | 11:28 PM
fiz's Avatar
fiz
no its goes like this from what I can see
Y-pipe, cat, s-pipe, i-pipe, muffler
I'm not sure if the s-pipe is stock since I didn't install it myself.
but either way, theres no way to put the borla i-pipe into it without welding it seems
Old Jan 30, 2003 | 01:10 AM
fiz's Avatar
fiz
bump
Old Jan 30, 2003 | 08:57 AM
didnt u get the clamps.....
Old Jan 30, 2003 | 03:43 PM
fiz's Avatar
fiz
yes but what do i do.. Just saw off the I-pipe? then put in the borla 3" pipe? will it fit and clamp on correctly?
Old Jan 31, 2003 | 03:04 AM
chesee48's Avatar
whats your name?
my nickname ( one of many) is fiz. my name is " Hafiz"
Old Jan 31, 2003 | 09:52 AM
nvmyws6's Avatar
GET A LOUDMOUTH!!!!
You won't regret it
Old Jan 31, 2003 | 10:19 PM
fiz's Avatar
fiz
I'm american.. my name is typical and not related to 'fiz'
Also, loudmouths sound horrible on 3.8L's (which I have)
ezcheeze15
Aug 26, 2002 01:28 PM
slothgrant
Aug 22, 2002 03:01 PM
MJ_Z28
Aug 8, 2002 09:07 PM
ezcheeze15
Aug 8, 2002 12:27 AM
MJ_Z28
Aug 7, 2002 07:15 PM
