Best cam for a daily driver/6 speed with bolt ons
If I don't sell this thing I'm thinking its time for a cam. I've heard good things about the Futral cams....any suggestions?
This is not a race car, but rather a daily driver that needs some more *****, so I don't want a full race cam that has a hard time idling or anything like that. Also, what valve springs would you recommend with the cam you recommend?
Anything else besides a dyno tune (and eventually tires) I will need?
224/228 .581/.588 112LSA is a good mild/moderate cam by today's standards.
Hardened pushrods and 918 springs should get 'er done. A good tune should put you easily over the 380rwhp mark too.
The Futral F-13 would be a perfect daily driver cam that will make over 400 rwhp with an LS6 intake manifold and ported stock TB with what you have in your sig - Not a ton of lope and great drivability.
It makes peak power at 6000 rpm and holds it until after 6500, so you can shift the car anywhere from 6200-6500 rpm.
I'd go with the PRC Duals or the Patriot Golds (don't need em, but I like em) along with titanium retainers.
Current shopping list:
F13 Cam
LS6 Intake
Patriot Gold Springs/Titanium retailers (is this a good deal: http://www.exoticperformanceplus.com....html?item=651)
Do I need pushrods too? Anything else I'm missing?
F13 Cam
LS6 Intake
F13 Cam
LS6 Intake
F13 Cam
LS6 Intake
Hardened Pushrods are REQUIRED... Also an LS2 Timing Chain Set is pretty necessary and an LS6 or ported oil pump wouldn't hurt.
I got my pushrods and timing chaing from TSP both were $127 at that time. and it is a good idea to get em. you will need the stock length of 7.4's.
So add those to your list and I think you will be set. Should hit 400rwhp or so.
Trevor98ramair
Jul 31, 2002 02:43 PM
Joe Brodman
Jul 24, 2002 05:24 AM
Black Sunshine/ 00SS
Jul 17, 2002 08:41 PM
