Best cam for a daily driver/6 speed with bolt ons
Old Jun 6, 2007 | 01:47 PM
Blue89Bird's Avatar
If I don't sell this thing I'm thinking its time for a cam. I've heard good things about the Futral cams....any suggestions?
This is not a race car, but rather a daily driver that needs some more *****, so I don't want a full race cam that has a hard time idling or anything like that. Also, what valve springs would you recommend with the cam you recommend?
Anything else besides a dyno tune (and eventually tires) I will need?
Old Jun 6, 2007 | 01:48 PM
SSpdDmon's Avatar
224/228 .581/.588 112LSA is a good mild/moderate cam by today's standards. Hardened pushrods and 918 springs should get 'er done. A good tune should put you easily over the 380rwhp mark too.
Old Jun 6, 2007 | 02:19 PM
Kraest's Avatar
Retired
The Futral F-13 would be a perfect daily driver cam that will make over 400 rwhp with an LS6 intake manifold and ported stock TB with what you have in your sig - Not a ton of lope and great drivability.
It makes peak power at 6000 rpm and holds it until after 6500, so you can shift the car anywhere from 6200-6500 rpm.
I'd go with the PRC Duals or the Patriot Golds (don't need em, but I like em) along with titanium retainers.
Old Jun 6, 2007 | 05:15 PM
Z28luvr's Avatar
can that F-13 cam be run with a stock converter?
Old Jun 6, 2007 | 07:50 PM
SSpdDmon's Avatar
Any cam bigger than an LS6 cam should have an aftermarket converter IMO.
Old Jun 6, 2007 | 10:14 PM
Kraest's Avatar
Retired
Yes, but even the stock motor needs a converter since it makes peak torque over 4000 rpm.
Old Jun 8, 2007 | 01:46 PM
Blue89Bird's Avatar
Current shopping list:
F13 Cam
LS6 Intake
Patriot Gold Springs/Titanium retailers (is this a good deal: http://www.exoticperformanceplus.com....html?item=651)
Do I need pushrods too? Anything else I'm missing?
Old Jun 8, 2007 | 02:12 PM
Kraest's Avatar
Retired
F13 Cam
LS6 Intake
Definetly a good deal. EPP is a good vendor.
Hardened Pushrods are REQUIRED... Also an LS2 Timing Chain Set is pretty necessary and an LS6 or ported oil pump wouldn't hurt.
Old Jun 8, 2007 | 02:35 PM
Megalis's Avatar
I got my pushrods and timing chaing from TSP both were $127 at that time. and it is a good idea to get em. you will need the stock length of 7.4's.
So add those to your list and I think you will be set. Should hit 400rwhp or so.
jmzlt1
Mar 13, 2003 07:26 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
Joe Brodman
Jul 24, 2002 05:24 AM
Black Sunshine/ 00SS
Jul 17, 2002 08:41 PM
