bassani off road pipe
Old Aug 21, 2003 | 07:41 AM
teke184's Avatar
how many of you guys are running this? or similar unit.
i know some companies just make the Ypipe from the cats back, but i want to replace the whole unit and delete the cats. i've wanted to get headers but i don't really have the money or means (be doing it alone and in a parking lot) to do this kind of project yet (maybe next year).
anyone know the size of the collector on the bassani? i assume 3" to accomodate after market catbacks but i've seen some of the aftermarket units only having the 2.75" to match the stock system. i have stock exhaust now but if i get a ORP i plan to put a 3" ssystem on, if nothing else 3" pipe back to an electric cutout before the axle then re-joining the stock exhaust (sleeper look but good flow when needed)
i don't expect much from the orp, maybe 10hp and some meaner sound. is that reasonable?
thanks
Old Aug 21, 2003 | 09:08 PM
bran_bro's Avatar
The Bassani oryp like I have for sale connects to the manifolds and does away with the cats all together. I first ran it with factroy catback then switched to 3 inch Borla cat back. The Bassini fit both just fine. (Best I can tell the Borla actually reduces to around 2.8" at y pipe connection to accomodate fitting factory y pipe and I would assume all the aftermarket 3" kits do the same thing.
Old Aug 22, 2003 | 12:29 AM
AL SS590 M6's Avatar
Moderator
Yep that's the bummer about trying to make everything bolt on.
All aftermarket cat backs are necked down to fit the factory y-pipe. And the Bassani OR y-pipe is necked down to fit all of the cat backs.
So what you get is a collecter with a 2 9/16" ID.
Well I cut the Bassani collecter off at the point where it is 3" then I cut the I-pipe of the loudmouth off where it is 3". I welded a 3" extension to the collecter and used a band clamp to hook the 2 together. Now I have 3" all the way.
Old Aug 22, 2003 | 07:22 PM
wilbs600's Avatar
I installed my bassani ofry about 2 weeks ago and I already had the loudmouth on. The collector fit perfect into the tail pipe. The only problem that I have now is that it pops now around 1700-2300 rpms. Besides that i love it any already 2 mustangs have complemented me even after I smoked them.
BLK1997Z28
May 7, 2015 03:01 PM
Russ95Z28
Apr 23, 2015 01:55 PM
Queens94z28
Mar 23, 2015 08:06 AM
1BADWS6
Aug 20, 2002 11:58 PM
Rippers_Evil_Twin
Aug 8, 2002 08:40 AM
