All Texas Speed & Performance lid owners inside
Old Aug 19, 2003 | 09:47 PM
Omega9's Avatar
Question All Texas Speed & Performance lid owners inside
For everyone who has a Texas Speed and Performance lid, I was wondering if they all fit rather poorly? My smoked clear lid seals up fine, but it isn't perfectly centered like the stock lid. Also, do all of the TSP lids have an area on each side that looks like it was glued with super glue? Otherwise, I'm happy with the lid.
Old Aug 19, 2003 | 10:00 PM
Beast96Z's Avatar
I've been waiting on mine for 3 months now. (85mm version) They say the reason they can't get me one out is because the epoxy keeps spliting and the lids fall in two. They tell me they are all "test fitted" before they leave the shop. I guess the glue you are referring to is for extra protection against splitting? If mine isn't nearly perfect, I'll send it back and get an MTI lid. Other than that the customer service has been good. Just the same excuse every time I call. Mine should be here tomm. , I'll post up how mine looks.
Old Aug 19, 2003 | 10:24 PM
redlt1z28's Avatar
Mine fits really good. It sits a little high but i think its because of the Frenco i put on there. I really like the design seems to be the best one.
Old Aug 19, 2003 | 11:48 PM
93TAWicked1's Avatar
Mine fit OK ALOT better than the whisper lid I had before. I don't remember any imperfections....
Old Aug 19, 2003 | 11:56 PM
SunsetWS6's Avatar
Wink
I had the TSP 85mm carbon fiber lid & it was great. I have the regular TSP carbon fiber lid now & it's just fine. As good a fit as any other lid I've had.
Old Aug 20, 2003 | 06:56 AM
teke184's Avatar
mine fit perfectly, and no visible blemishes.
one thing that i did do was to cut a small section out of the radiator shroude just under the "tube section" of the lid. i did this because i had a ZO6 maf on there and the coupling tube that it came with (to connect the maf to the lid since i didn't have the 85mm lid) pressed against the shroud, causing it to sit higher and not line up. and after i switched back to the stock maf it seemed to fit even better since that section of material wasn't in the way.
i'll try to get a shot of it some time to show you what i mean...
other than that i'm very pleased with my lid...only took 2 weeks to get to...but it's the black one
Old Aug 20, 2003 | 09:39 AM
94B&RZ-28's Avatar
I have the TSP smoaked clear lid and my fit was perfect.
Old Aug 20, 2003 | 09:50 AM
SSCamaro99_3's Avatar
I am very happy with mine.
Old Aug 21, 2003 | 10:37 PM
Beast96Z's Avatar
Mine came in today. I see no negative things to say about it, and I have no "glue" on mine. I read a few other threads on ls-1.com and tech, and they said it seems to only be the clear style lids that they are putting this stuff on..
Old Aug 21, 2003 | 11:19 PM
Omega9's Avatar
I'm sure its on all of their lids, you can just see it with the clear though.
Old Aug 22, 2003 | 06:07 AM
Kevyn's Avatar
My fit is OK but the glue residue looks like ***.
Old Aug 22, 2003 | 04:46 PM
Beast96Z's Avatar
Like you said though, mine is not centered. Looks like they were off on the mold a little.
Old Aug 22, 2003 | 05:42 PM
BigZ28's Avatar
Beast96Z, Omega9- I have had a couple of phone calls describing what you are talking about. Just make sure that the radiator support is lined up. You might want to loosen it up and move it towards the passenger side some to see if that helps.
Brian
Old Aug 22, 2003 | 08:02 PM
Beast96Z's Avatar
I'll give it a shot. Thanks
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Chris 96 WS6
Jun 27, 2002 05:03 PM
