Autometer Shift Light Installation?
Old May 25, 2003 | 07:02 PM
CSULAZ28's Avatar
I've got a '00 LS1 and have looked everywhere for the install guide for the Autometer shift light. Can any members post how to install it or post a link to the instructions. Thanks in advance.
Old May 25, 2003 | 10:02 PM
1BADAIR's Avatar
Do you have the little shift light that has the RPM activation module that takes RPM pills. If so the black wire = - ,red +, and green wire goes to pin 10/white wire on the front PCM connector.
My rpm box is set for a 4 cylinder
Old May 25, 2003 | 10:10 PM
CSULAZ28's Avatar
Thanks a lot for helping me out. I kept my fingers crossed hoping a member would help me out. You answered my cries. WOOHOO!! thanks a lot.
-Steven
Old May 25, 2003 | 10:20 PM
1BADAIR's Avatar
No problem.
If you want to look at a diagram go to Autometer.com and look in the instruction/wiring section.
Old May 26, 2003 | 01:17 AM
CSULAZ28's Avatar
Thanks I'll take a look at the site. I ran into a problem while trying to do the install. Where exactly is the pin 10/white wire? Could you please give me a step by step list if it's not too much trouble. So far, I pulled my computer out about half way (I couldn't pull the comp. all the way out because there's about 3 or 4 bunched of wire harnesses holding it down.
Old May 26, 2003 | 04:24 AM
My84Z's Avatar
http://www.fbody.com/members/safbody/faq/shftlite.htm
Old May 26, 2003 | 08:09 AM
1BADAIR's Avatar
It would be the connector thats closest to the front of the car on the pcm. Pinch the little tabs on the ends of the gray cover. Once you get the cover off the pins are numbered. It is the 10th wire over from the left on the top row of wires.
Old May 26, 2003 | 03:47 PM
CSULAZ28's Avatar
Woohoo! I found it. All I gotta do now is drill a hole into the firewall and slap a grommet in there and voila. Thanks guys for your help. I'm definitely gonna gonna take pics of the whole process for any future members. Thanks again guys!
GigaMp3z
Feb 20, 2003 02:57 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Krab
Aug 5, 2002 12:08 AM
