Anyone ever tried out the Typhoon manifolds
Old Dec 13, 2008 | 08:08 PM
  #16
silverz28camaro's Avatar
Originally Posted by danhr
http://www.ls1tech.com/forums/genera...typhoon-7.html
What happens when you have a nitrous backfire with an ls6 intake?
What happens when you have a nitrous backfire with a typhoon intake?
Which third grader drew this up? And is this at the wheels or at the flywheel? If its at the flywheel then it prolly only 8 at the wheel, Fast will net more and be lighter.
If it is at the wheel then it only proves the the ls6 is a slight restriction on a 500RWHP application
Old Dec 13, 2008 | 10:13 PM
  #17
danhr's Avatar
Originally Posted by silverz28camaro
Well then guess what get a window switch, or a progressive controller, there are more ways to use nitrous then just on the limiter!
If you think a windows switch/progressive controller is going to protect you 100% from a nitrous backfire, you should never use nitrous.
The dyno graph was pulled off of byunspeed's website. There are more on PP web page, a few scattered on ls1tech, and a lot more vendor's websites.
and why would someone compare it to a fast? it's supposed to be a competitor against the ls6.
and yes... it will be lighter... a whole 5 lbs lighter... lay off the fast food for a week and you get that weight back.
and there is also the fact that come with upgraded fuel rails with a -6 crossover, and -an fittings for fuel lines and nitrous.
The fact that you people say that one intake is solely better than the rest is ridiculous. Each engine is different and has different requirements.
Old Dec 14, 2008 | 02:39 PM
  #18
Marc 85Z28's Avatar
In this case you know this because...? Do you have any firsthand experience with this intake? And if not, can you provide any independant evidence that it outperforms the LS6 - aside from someone attempting to make a sale?
I've seen the Typhoon tested against an LS6 on a fairly typical heads and cam setup, having the intake swapped on the dyno. Not only did the LS6 intake make more power everywhere (albeit by very little), but it fit right the first time, and made more power each consecutive pull. The Typhoon on the other hand lost 3-4hp every time it was run.
It's nice that they come with the fuel rails for the price, but the Typhoon has always been a form over function intake. Most everyone buys it for the bling.
Old Dec 15, 2008 | 05:35 PM
  #19
Kraest's Avatar
Retired
Just to let you know...
If you're using a dry shot, your chances of blowing up your plastic intake are very very small.... if you're pumping fuel into it as well as nitrous, well.....
GREEN3112
Feb 10, 2019 09:19 PM
HibachiZ28
Nov 6, 2015 12:53 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Zrout
Parts Wanted
Sep 1, 2015 06:32 PM
ShiftyCapone
Aug 27, 2015 10:14 AM
